[Other] Override symmetryPlane Boundary condition
Old   December 1, 2014, 16:46
Default Override symmetryPlane Boundary condition
Gavin
gwj_gavin is on a distinguished road
Hi, Foamers,
Is there anyway to override the symmetryPlane boundary condition?
It seems once the boundary patch is created as symmetryPlane, no other boundary type can be used in the case file setting(e.g. case/0.1).
But for my problem, I need to solve other equations after solving fluid(N-S related) equations, which requires other boundary conditions other than symmetryPlane for that patch. Meanwhile the fluid parts shall keep using the symmetryPlane BC.
For example,
A patch of a mesh is generated as symmetryPlane in blockMeshDict
And all variables related to fluids equations for that patch are set as symmetryPlane
But for other variables, they can be set as fixedValue or others for that patch.
Thanks
gwj_gavin is offline   Reply With Quote
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 02:54
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
