STL file conversion
Hello guys,
I am new to this awesome forum. Currently i am doing my masters and started with my student project in OpenFOAM. I am using snappyHexMesh for the grid generation. I have converted my CAD model into a stl file. since my CAD model deals with mm i assume that i should also convert my surface points in the stl file to meters. What i am doing is right? or Can any one comment on this please. note: I am setting up my problems in meter. with regards, Dinesh |
Hi Dinesh,
i guess its surfaceTransformPoints -scale you are searching for: [CODE] surfaceTransformPoints -scale '(x.xx y.yy z.zz)' [CODE] For example from mm to m the scalefactors '(x y z)' are '(0.001 0.001 0.001)'. right? Aloha! Good luck to your Thesis!! qwert |
Hi qwert,
thanks for your reply. I meant that since my stl file are in 'mm'. I should convert them to meters in order use them for meshing? What i am doing is correct?. Or should i use the original stl file with 'mm'. with regards, Dinesh |
maybe i didn't get the point. However, if you have a stl-File with your triangles in mm and you want that file to convert in meters, since your calculation will use a metric system, you can use the surfaceTransform: (im my opinion you always should have a metric system for your calculation, if that was the point) 1. Go in the directory where you have the original stl-file (in mm) 2. use: Quote:
Best regards, qwert |
