November 8, 2021, 09:49 |
non-orthogonality problem
Tommaso Negosanti
Rep Power: 4 |
Hello all,
In the current study i'm following i need to mesh a complex body. I decided to use snappyHexMesh since it has a good mesh capability and meshes with hexaedral elements. The sHM process end with no problems exept the fact that i get a lot of non-orthogonals elements on my mesh, about 5000. I don't get what i' m doing wrong Here is the blockMeshDict file for the background mesh: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; //x [-250;100] //y [0;170] //z [0;11.273] vertices ( (-300 0 0) (500 0 0) (500 300 0) (-300 300 0) (-300 0 11) (500 0 11) (500 300 11) (-300 300 11) ); blocks ( hex (0 1 2 3 4 5 6 7) (80 30 11) simpleGrading (1 1 1) edges (); boundary ( inlet { type patch; faces ( (0 3 7 4) ); } outlet { type patch; faces ( (1 2 6 5) (7 6 2 3) ); } front_back { type empty; faces ( (0 3 2 1) (5 6 7 4) ); } symmetry { type symmetryPlane; faces ( (0 1 5 4) ); } ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object surfaceFeaturesDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // wall { surfaces ("wall.stl"); includedAngle 90; geometricTestOnly yes; writeObj yes; } porous_domain { surfaces ("porous_domain.stl"); includedAngle 90; geometricTestOnly yes; writeObj yes; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers true; geometry { wall { type closedTriSurfaceMesh; file "wall.stl"; } porous_domain { type closedTriSurfaceMesh; file "porous_domain.stl"; } refinementBox { type searchableBox; min (-0.3 0 0); max (0.25 0.2 0.011); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ maxLocalCells 100000000; maxGlobalCells 200000000; minRefinementCells 10; maxLoadUnbalance 0.10; nCellsBetweenLevels 2; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features ( { file "wall.eMesh"; levels ((2 3)); } { file "porous_domain.eMesh"; levels ((2 2)); } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces { wall { level (0 0); patchInfo { type wall; } } porous_domain { level (2 2); faceZone porous_domain; cellZone porous_domain; cellZoneInside inside; boundary internal; patchInfo { type patch; } } } resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ refinementRegions { refinementBox { mode inside; level 1; } } // Mesh selection // ~~~~~~~~~~~~~~ locationInMesh (-0.25 0.001 0.005); allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 5; tolerance 4.0; nSolveIter 100; nRelaxIter 5; // Feature snapping nFeatureSnapIter 30; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { relativeSizes false; layers { wall { nSurfaceLayers 5; } } expansionRatio 1.2; finalLayerThickness 0.2; minThickness 0.1; nGrow 0; featureAngle 30; slipFeatureAngle 30; nRelaxIter 3; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; } meshQualityControls { #include "meshQualityDict" } debug 1; writeFlags ( scalarLevels layerSets layerFields ); mergeTolerance 1e-6; // ************************************************************************* // The .stl files are exported from a geometry i modeled in salome. Last edited by tommynego95; November 11, 2021 at 04:46. |
Display Modes | |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 20:41 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
