Meshes made of several blocks
Hi!
I am trying to make a mesh made of several blocks in order to have a geometry containing obstacles but I keep obtaining error messages about faces that don't have neighbour cell faces. I can reproduce the problem by trying to make a mesh made of 2 blocks inside a cube. In blockMeshDict, I create a cube and I add 4 points in the middle, along the y axis, to slice it in half. Quote:
Thank you! Cheers, Philippe |
In general the error means you have messed up definition of patches (boundary section). Can you post your whole blockMeshDict as an attachment? |
Hello!
Thank you for your reply. Here is the boundary section. Quote:
Cheers, Philippe |
Patches in general composed of boundaries of the blocks. If you cut cube, you cut boundaries. So what was described before cutting as a single face should be described as several faces. |
I have sliced the boundaries in 2.
Thanks. Philippe |
Start with visualizing your blocks, to check if you have made mistake there. I.e. you comment out patches definitions, run blockMesh, open mesh in paraview. Your vertices look rather suspicious, among four additional points for some reason ( 0 10 0) appeared. Also I am not quite sure in correctness of your vertices numbering in blocks definitions. I can try to reconstruct the case from the pieces you have posted and try to look for error but I would rather wait till you post archive with the case files. |
