[Salome] import mesh from salome to openfoam
Old   May 18, 2015, 10:24
Default import mesh from salome to openfoam
domenico
dome90 is on a distinguished road
Hi I'm very new in openFoam, and I'm sorry for my basic english! However I'm building the geometry and the mesh for a static mixer with salome but when I import yhe mesh openform cannot generate the mesh... This is the error
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:" SI: Meter (newton)"
unitType:2
Unit factors:
Length scale : 1
Force scale : 1
Temperature scale : 1
Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 2300 points.
Processing tag:2412
Starting reading cells at line 4623.
First occurrence of element type 11 for cell 1 at line 4624
First occurrence of element type 41 for cell 425 at line 5896
Read 0 cells and 4596 boundary faces.
Processing tag:2467
Starting reading patches at line 15090.
For group 1 named wall trying to read 4596 patch face indices.
Sorting boundary faces according to group (patch)
0: wall is #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Errore di segmentazione (core dump creato)
Please somebody can help me?
dome90 is offline   Reply With Quote
Old   April 20, 2016, 08:23
dklogo
logo is on a distinguished road
Hi domenico,
i am facing the same problem with you . Did you find a solution ? If yes, can you give some help with this ?
logo is offline   Reply With Quote
Old   April 20, 2016, 23:58
kkk
kenyoh
kkk is on a distinguished road
Hi
This might help you.
Just give it try.
http://www.cfd-online.com/Forums/blo...onversion.html
https://github.com/nicolasedh/salome...eToOpenFOAM.py
Regards,
kkk
kkk is offline   Reply With Quote
[Salome] mesh conversion Salome --> OpenFoam vaina74 OpenFOAM Meshing & Mesh Conversion 42 March 4, 2022 20:41
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[ANSYS Meshing] Import Mesh from CFX-Solve to OpenFOAM A.Stamatopol ANSYS Meshing & Geometry 1 July 25, 2013 11:08
Converting Salome hybrid mesh to OpenFOAM Arnoldinho OpenFOAM 4 March 28, 2012 10:24
