[blockMesh] Error while creating blockMesh: Inconsistent point locations between block pair
Old   May 30, 2015, 11:25
Default Error while creating blockMesh: Inconsistent point locations between block pair
Ashwin
lpashwin is on a distinguished road
Ok sorry for the post, I figured out what my mistake is and corrected it.
I am a novice OpenFoam user and I ran into this problem which running blockMesh. Can someone explain to me why I am getting this error?
Creating block offsets
Creating merge list
--> FOAM FATAL ERROR:
Inconsistent point locations between block pair 0 and 2
probably due to inconsistent grading.
From function blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 294.
FOAM exiting
My blockMeshDict is as shown below
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
( -1000.0 -500.0 -200.0) //0
( 0.0 -500.0 -200.0) //1
(1000.0 -500.0 -200.0) //2
( -1000.0 0.0 -200.0) //3
( 0.0 0.0 -200.0) //4
(1000.0 0.0 -200.0) //5
( -1000.0 500.0 -200.0) //6
( 0.0 500.0 -200.0) //7
(1000.0 500.0 -200.0) //8
( -1000.0 -500.0 200.0) //9
( 0.0 -500.0 200.0) //10
(1000.0 -500.0 200.0) //11
(-1000.0 0.0 200.0) //12
( 0.0 0.0 200.0) //13
(1000.0 0.0 200.0) //14
( -1000.0 500.0 200.0) //15
( 0.0 500.0 200.0) //16
(1000.0 500.0 200.0) //17
blocks
hex (0 1 4 3 9 10 13 12) (200 100 40) simpleGrading (0.1 1 0.1)
hex (1 2 5 4 10 11 14 13) (200 100 40) simpleGrading (0.1 1 0.1)
hex (3 4 7 6 12 13 16 15) (200 100 40) simpleGrading (10. 1 0.1)
hex (4 5 8 7 13 14 17 16) (200 100 40) simpleGrading (10. 1 0.1)
edges
boundary
atmosphere
type patch;
faces
(9 10 13 12)
(10 11 14 13)
(13 14 17 16)
(12 13 16 15)
inlet
type patch;
faces
(0 1 10 9)
(1 2 11 10)
outlet
type patch;
faces
(16 17 8 7)
(15 16 7 6)
bottom
type wall;
faces
(0 3 4 1)
(3 6 7 4)
(4 7 8 5)
(1 4 5 2)
lsides
type wall;
faces
(5 14 11 2)
(8 17 14 5)
rsides
type wall;
faces
(9 12 3 0)
(12 15 6 3)
mergePatchPairs
lpashwin is offline   Reply With Quote
Old   May 30, 2015, 18:34
Alexander Bartel
alexB is on a distinguished road
Hi Ashwin,
the mesh grading between block 0 and 2, and between 1 and 3 doesn't fit.
The first block has a 0.1 grading in x-direction and the second has 10 in x-direction while they are connected in the x-z-plane.
Just choose the same value for the grading and it should work.
regards
Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
alexB is offline   Reply With Quote
Old   June 1, 2015, 12:31
Ashwin
Thank you Alex! It works now!
blockmeshdict block mesh
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 14:54
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 16:37
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 13:13
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
