OpenFoam Error Message: "no cells read from file .msh"
Hello all.
I've just made my first 2d mesh with GMSH i think it's corretly written. Now i try to load it to OpenFoam but it returns me this error: "no cells read from file .msh Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4) " my mesh is 2D. Does anyone know the problem? Thanks :D:D this is my .geo: // Gmsh project created on Sat Jun 13 11:37:29 2015 Point(1) = {1, 0, 0, 1}; Point(3) = {0.99572, 0.00057, 0, 0.0001}; Point(5) = {0.98296, 0.00218, 0, 0.0001}; Point(6) = {0.96194, 0.00463, 0, 0.0001}; Point(7) = {0.93301, 0.0077, 0, 0.0001}; Point(8) = {0.89668, 0.01127, 0, 0.0001}; Point(9) = {0.85355, 0.01522, 0, 0.0001}; Point(10) = {0.80438, 0.01945, 0, 0.0001}; Point(11) = {0.75, 0.02384, 0, 0.0001}; Point(12) = {0.69134, 0.02823, 0, 0.0001}; Point(13) = {0.62941, 0.03247, 0, 0.0001}; Point(14) = {0.56526, 0.03638, 0, 0.0001}; Point(15) = {0.5, 0.03978, 0, 0.0001}; Point(16) = {0.43474, 0.04248, 0, 0.0001}; Point(17) = {0.37059, 0.04431, 0, 0.0001}; Point(18) = {0.33928, 0.04484, 0, 0.0001}; Point(19) = {0.30866, 0.04509, 0, 0.0001}; Point(20) = {0.27886, 0.04504, 0, 0.0001}; Point(21) = {0.25, 0.04466, 0, 0.0001}; Point(22) = {0.22221, 0.04397, 0, 0.0001}; Point(23) = {0.19562, 0.04295, 0, 0.0001}; Point(24) = {0.17033, 0.04161, 0, 0.0001}; Point(25) = {0.14645, 0.03994, 0, 0.0001}; Point(26) = {0.12408, 0.03795, 0, 0.0001}; Point(27) = {0.10332, 0.03564, 0, 0.0001}; Point(28) = {0.08427, 0.03305, 0, 0.0001}; Point(29) = {0.06699, 0.03023, 0, 0.0001}; Point(31) = {0.05156, 0.0272, 0, 0.0001}; Point(32) = {0.03806, 0.02395, 0, 0.0001}; Point(33) = {0.02653, 0.02039, 0, 0.0001}; Point(34) = {0.01704, 0.01646, 0, 0.0001}; Point(35) = {0.00961, 0.01214, 0, 0.0001}; Point(36) = {0.00428, 0.00767, 0, 0.0001}; Point(37) = {0.00107, 0.00349, 0, 0.0001}; Point(38) = {0, 0, 0, 0.0001}; Point(39) = {0.00107, -0.00349, 0, 0.0001}; Point(40) = {0.00428, -0.00767, 0, 0.0001}; Point(41) = {0.00961, -0.01214, 0, 0.0001}; Point(42) = {0.01704, -0.01646, 0, 0.0001}; Point(43) = {0.02653, -0.02039, 0, 0.0001}; Point(44) = {0.03806, -0.02395, 0, 0.0001}; Point(45) = {0.05156, -0.0272, 0, 0.0001}; Point(46) = {0.06699, -0.03023, 0, 0.0001}; Point(47) = {0.08427, -0.03305, 0, 0.0001}; Point(48) = {0.10332, -0.03564, 0, 0.0001}; Point(49) = {0.10332, -0.03564, 0, 0.0001}; Point(50) = {0.12408, -0.03795, 0, 0.0001}; Point(51) = {0.14645, -0.03994, 0, 0.0001}; Point(52) = {0.17033, -0.04161, 0, 0.0001}; Point(53) = {0.19562, -0.04295, 0, 0.0001}; Point(54) = {0.22221, -0.04397, 0, 0.0001}; Point(55) = {0.25, -0.04466, 0, 0.0001}; Point(56) = {0.27886, -0.04504, 0, 0.0001}; Point(57) = {0.30866, -0.04509, 0, 0.0001}; Point(58) = {0.33928, -0.04484, 0, 0.0001}; Point(59) = {0.33928, -0.04484, 0, 0.0001}; Point(60) = {0.37059, -0.04431, 0, 0.0001}; Point(61) = {0.43474, -0.04248, 0, 0.0001}; Point(62) = {0.5, -0.03978, 0, 0.0001}; Point(63) = {0.56526, -0.03638, 0, 0.0001}; Point(64) = {0.62941, -0.03247, 0, 0.0001}; Point(65) = {0.69134, -0.02823, 0, 0.0001}; Point(66) = {0.75, -0.02384, 0, 0.0001}; Point(67) = {0.80438, -0.01945, 0, 0.0001}; Point(68) = {0.85355, -0.01522, 0, 0.0001}; Point(69) = {0.89668, -0.01127, 0, 0.0001}; Point(70) = {0.93301, -0.0077, 0, 0.0001}; Point(71) = {0.96194, -0.00463, 0, 0.0001}; Point(72) = {0.98296, -0.00218, 0, 0.0001}; Point(73) = {0.99572, -0.00057, 0, 0.0001}; Spline(1) = {38, 37, 36, 35, 34, 33, 32, 31, 29, 28, 27, 26, 25, 24, 23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 3, 1, 73, 72, 71, 70, 69, 68, 67, 66, 65, 64, 63, 62, 61, 60, 58, 57, 56, 55, 54, 53, 52, 51, 50, 48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38}; Point(74) = {7, 5, 0, 1.0}; Point(75) = {7, -5, 0, 1.0}; Point(76) = {-7, -5, 0, 1.0}; Point(77) = {-7, 5, 0, 1.0}; Point(78) = {7, 0.5, 0, 1.0}; Point(79) = {7, -0.5, 0, 1.0}; Point(80) = {0, 0, 0, 0.0001}; Point(81) = {0, 0.5, 0, 1.0}; Point(82) = {0, -0.5, 0, 1.0}; Point(83) = {-0.5, 0, 0, 1.0}; Line(2) = {76, 77}; Line(3) = {77, 74}; Line(4) = {74, 78}; Line(5) = {78, 81}; Line(6) = {82, 79}; Line(7) = {79, 75}; Line(8) = {75, 76}; Line(9) = {78, 79}; Circle(10) = {81, 80, 83}; Circle(11) = {83, 80, 82}; Line Loop(12) = {2, 3, 4, 5, 10, 11, 6, 7, 8}; Plane Surface(13) = {12}; Line Loop(14) = {5, 10, 11, 6, -9}; Line Loop(15) = {1}; Plane Surface(16) = {14, 15}; Physical Line("Left") = {2}; Physical Line("Top") = {3}; Physical Line("Right") = {4, 9, 7}; Physical Line("Bottom") = {8}; Physical Line("Airfoil") = {1}; |
Hi Kayla,
OpenFOAM can only handle 3D grids. You have to extrude your 2D mesh in gmsh before you can work with it. Best regards, Kate |
