Home > Forums > OpenFOAM Meshing & Mesh Conversion
How to create a subpatch from a patch
Old   July 9, 2015, 13:36
Default How to create a subpatch from a patch
Marcel Vonlanthen
Sylv is on a distinguished road
Dear Foamer,
I have the mesh of a hilly terrain (very similar to the tutorial of moveDynamicMesh). The mesh is composed by the following boundaries:
  • north
  • south
  • east
  • west
  • top
  • ground
I want to extract from "ground" a sub-patch named "hill". To do this, I am thinking about using createPatch, but I need a faceSet with ONLY patch faces, and this is very problematic. My strategy was to use toposet like this:
  • create a cellSet with boxToCell. The box enclosed the faces that will be part of "hill" (easy)
  • create a faceSet with cellToFace (easy)
From this faceSet, I have to remove the internal faces. How can I do that?
Or is there a better option?
Cheers,
Marcel
Sylv is offline   Reply With Quote
Old   July 10, 2015, 16:59
Alexey Matveichev
alexeym will become famous soon enoughalexeym will become famous soon enough
Send a message via Skype™ to alexeym
You can use subset action in topoSetDict, it would be something like:
        name hill;
        type faceSet;
        action subset;
        source patchToFace;
        sourceInfo
            name "ground";
Where hill is the name of faceSet you have created with cellToFace.
alexeym is offline   Reply With Quote
Old   November 7, 2015, 16:23
Himanshu Sharma
himanshu28 is on a distinguished road
Originally Posted by Sylv View Post
Dear Foamer,
  • north
  • south
  • east
  • west
  • top
  • ground
Cheers,
Marcel
Hi Marcel & Alexey,
I am also trying to achieve similar thing as Marcel showed in the post, for my problem I have following patches:
1) Top wall 2) Left wall
I want to extract only few faces on Top Wall and left wall and build the faceset
(faces of Interest)
|_
| (Faces of Interest)
|_
I am trying the approach as Alexey told but how should I make sure that the "subset" is the set of my interest I will be thankful to both if you can give some detail about the approach .
Thank you
Regards
himanshu28 is offline   Reply With Quote
Old   November 7, 2015, 17:44
Alexey Matveichev
Maybe I am missing something but...
1. Select cells near top wall. You know location of the top wall, you know size of the cells there, so it should not be a problem. Create faceSet with cellToFace action. Then subSet these faces with patchToFace.
2. Repeat the same with "Left wall".
3. Then you use createPatch utility (maybe you will need to merge faceSets before creating patch, it is done with add action).
Old   November 7, 2015, 19:18
Himanshu Sharma
Originally Posted by alexeym View Post
Hi alexeym,
Thanks for the Help. Its working out
Regards
Thread Tools
Trackbacks are On
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 110 April 21, 2016 11:54
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
Fluent3DMeshToFoam simvun OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 48 May 14, 2012 05:20
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 08:19
