[Salome] Salome generating facezone instead of patches |
September 13, 2015, 23:58 |
Franco
Rep Power: 10 |
I'm trying to solve a chtMultiRegionFoam problem and I'm creating the geometry and the mesh on Salome. I'm having troubles when I export the geometry to OpenFoam: in fact, when I lunch the command ideasUnvToFoam, I realize that some of my faces are patches (as it should be), and others are facezone. This is giving me some problems, since when I use the command ideasUnvToFoam, I get the following error ideasUnvToFoam: ideasUnvToFoam.C:1273: int main(int, char**): Assertion `noveau > -1' failed. Aborted (core dumped) Could anyone help me please? I'll leave you my hdf file Thanks in advance!!! |
September 19, 2015, 13:00 |
Franco
Rep Power: 10 |
problem solved, I made a new geometry and I defined all the faces of the geometry
December 15, 2016, 15:11 |
Thodoris
Rep Power: 10 |
Could you please tell me exactly what you did because i have done everything but still i have a facezone or cellzone boundary
December 16, 2016, 10:58 |
Franco
Rep Power: 10 |
The problem raises once you generate a face (for instance, once you make an extrusion) that is an interface between two objects (two solids or one fluid and one solid). So, what you can do is to check that every extrusion has its own faces (and not "shared" faces): one way to solve this problem is to generate the faces (that will be used for extrusion) from lines; then, these lines will not be used by any other extrusion face.
I hope it helps! Franco |
December 17, 2016, 14:23 |
Thodoris
Rep Power: 10 |
Excuse me Franco but can i send you my hdf file so you can see exactly which is the problem?Thank you very much in advance.
December 19, 2016, 09:47 |
Franco
Rep Power: 10 |
Hi Thodoris
Upload the case in the forum, I'll give it a look later... Franco |
salome patches facezone |
Problem using AMI | vinz | OpenFOAM Running, Solving & CFD | 298 | November 13, 2023 08:19 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
Regarding periodic BC in ICEM generated grid | Tarak | OpenFOAM | 32 | April 30, 2013 14:46 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 11:40 |
