STL format in SnappyHexMesh
1 Attachment(s)
Dear all,
I generated a STL file with Salome-meca 2015.1, but I don’t know how should it be done …,I sketch a curve consist of coordaniate of points of airfoil and connect them with spline curve,,extrude it 1 cm around z axis so export it in STL format but it seems strange I have attached the picture Can I use it for snappyHexMesh? Best regards Samira |
Hello Samira,
Your STL must be closed in order to generate a mesh for an external flow, as I imagine that what you are trying to do.You need to generate triangles on both sides of the wing. Daniel |
Dear Daniel
Thank you very much for the reply..yes,,I'm working on airfoil shape optimization for wind turbine by openfoam.. how do I generate triangles on both sides of the wing? Can you please provide me step-by-step instructions for creating it? Thanks |
Hi samira,
I found a good step by step tutorial by youtube https://www.youtube.com/watch?v=ObsFQUiVi1U regards Alex edit: I think Daniels link fits better, because snappyHexmesh is probably not the best program for your problem. |
Hi
Daniel, Thanks a lot for your help,I really appreciate it..your advice proved very useful to me Alex, Thank you,Suggest Link certainly will be very useful for me in next step Best regards Samira |
