[snappyHexMesh] In need of guidance to optimize snappyHexMeshDict for a rotor segment
Old   August 8, 2015, 01:14
Default In need of guidance to optimize snappyHexMeshDict for a rotor segment
Zach
ZachJa is on a distinguished road
I am trying to make snappyHexMesh for the following rotor segment with the following patches:
https://www.dropbox.com/s/im59eo76bc...tches.png?dl=0
However, my current snappyHM setup:
https://www.dropbox.com/s/ggjqomezqn...xMeshDict?dl=0
is not OK cause result mesh:
https://www.dropbox.com/s/1uotklsyxb...0mesh.png?dl=0
is not suitable for simulation.
How should I modify snappyHM setup to achieve smth like this:
https://www.dropbox.com/s/b8ipmjgztx...0mesh.png?dl=0
ie I need more homogeneous mesh distribution especially at outlet and periodic faces.
Thank you for any help!
ZachJa is offline   Reply With Quote
Old   August 15, 2015, 01:04
Zach
looks like blockMesh is important, especially for rotating geometry. I suppose that non-homogeneous mesh on radiused surfaces is because of quadratic blocks in blockMesh. I am wondering: is it possible to make blockMesh using cylinder (sector of cylinder) like this: https://www.dropbox.com/s/fuo4wdq116gmgo2/Cyl1?dl=0 instead of quadratic block?
Old   August 17, 2015, 11:11
DanielP
danielpiaget is on a distinguished road
Hello ZanJa,
See the link below where they have split up the domain for application in turbines and diffusers (hybraulic machinery) using blockMesh.
http://openfoamwiki.net/index.php/Si...nical_diffuser
See in particular section 1.6.
Note that they have used the utilty m4 to generate the blockMeshdict.
http://www.gnu.org/doc/doc.html
Good luck,
Daniel
danielpiaget is offline   Reply With Quote
snappy hex mesh
[Other] howto optimize OpenFOAM for Core i7 CPU using extended instruction set cutter OpenFOAM Installation 6 December 28, 2015 20:19
[snappyHexMesh] How to define the computational region with snappyHexMeshDict xurenyi OpenFOAM Meshing & Mesh Conversion 3 June 12, 2014 09:20
[ANSYS Meshing] Request guidance on exporting mesh from ICEM to fluent nauman55 ANSYS Meshing & Geometry 0 February 16, 2013 10:54
