[swak4Foam] GroovyBC installation Error
Old   August 25, 2015, 15:05
Default GroovyBC installation Error
Douglas Wellington Pontes
Douglas is on a distinguished road
I tried installing "GroovyBC" on my computer and when I type "wmake libso" (as directed on the site : https://openfoamwiki.net/index.php/Contrib/groovyBC ) in the files folder I get the following error:
/opt/openfoam240/src/OpenFOAM/lnInclude/Field.C:235:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::Field<Foam::Tensor<double> > >’ to ‘const Foam::UList<Foam::SymmTensor<double> >&’
/opt/openfoam240/src/OpenFOAM/lnInclude/Field.C:54:1: note: Foam::Field<Type>::Field(Foam::label, const Type&) [with Type = Foam::SymmTensor<double>; Foam::label = int]
Foam::Field<Type>::Field(const label size, const Type& t)
/opt/openfoam240/src/OpenFOAM/lnInclude/Field.C:54:1: note: candidate expects 2 arguments, 1 provided
/opt/openfoam240/src/OpenFOAM/lnInclude/Field.C:47:1: note: Foam::Field<Type>::Field(Foam::label) [with Type = Foam::SymmTensor<double>; Foam::label = int]
Foam::Field<Type>::Field(const label size)
/opt/openfoam240/src/OpenFOAM/lnInclude/Field.C:47:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::Field<Foam::Tensor<double> > >’ to ‘Foam::label {aka int}’
/opt/openfoam240/src/OpenFOAM/lnInclude/Field.C:40:1: note: Foam::Field<Type>::Field() [with Type = Foam::SymmTensor<double>]
/opt/openfoam240/src/OpenFOAM/lnInclude/Field.C:40:1: note: candidate expects 0 arguments, 1 provided
PatchValueExpressionParser.tab.cc: In member function ‘pve::PatchValueExpressionParser::token_number_typ e pve::PatchValueExpressionParser::yytranslate_(int) ’:
PatchValueExpressionParser.tab.cc:4941:24: warning: use of old-style cast [-Wold-style-cast]
make: *** [Make/linux64GccDPOpt/PatchValueExpressionParser.o] Error 1
The version of "Bison" installed on my computer 2.4.1 (as stated on the website), my version of OpenFoam is the 2.4 with Ubuntu LTS 2014.
What is wrong? I tried installing GroovyBC using the newest version of "Bison" and there was a similar error
Douglas is offline   Reply With Quote
boundary conditions, groovybc, openfoam
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
