[Gmsh] GMSH: Meshing a cylinder with a HUGE number of points |
August 9, 2017, 16:44 |
Marc
Rep Power: 10 |
Hi folks,
I need to mesh a cylinder with a VERY FINE mesh. Point(1) = {0,0,0,0.01}; Point(2) = {0.012,0,0,0.001}; Point(3) = {0,0.012,0,0.001}; Point(4) = {-0.012,0,0,0.001}; Point(5) = {0,-0.012,0,0.001}; Circle(1) = {2,1,3}; Circle(2) = {3,1,4}; Circle(3) = {4,1,5}; Circle(4) = {5,1,2}; Line Loop(5) = {1,2,3,4}; Plane Surface(6) = {5}; Extrude {0,0,0.040} { Surface{6}; } Unfortunately, that doesn't work at all. After I have created a 2D-meshing, the 3D-meshing gets stuck, probably because there are really too many points. Is there a way to surmount this problem? Many thanks in advance. |
August 10, 2017, 15:17 |
1. What Gmsh version do you use? 3.0.1 generates mesh quite easily, and the mesh is not so fine. Also what mesh generators are in your settings? 2. Do you really want coarser mesh near point 1 or it is just typo? |
Display Modes | |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 10:15 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 11:37 |
