November 9, 2015, 06:53 |
Inadequate mesh resolution (CfMesh)
Rajukiran Antham
Rep Power: 13 |
I am new to OpenFoam. I am trying to mesh my geometry using cfmesh. I am using only the mandatory settings for my MeshDict file. when i try to run cartesianMesh it gives the following error. I had a maxcellSize of 2 --> FOAM FATAL ERROR: There are no cells in the mesh! The reasons for this can be fwofold: 1. Inadequate mesh resolution. 2. You maxCellSize is a multiplier of the domain length. This can be reolved by reducing the maxCellSize by a fraction.i.e. 2.49999 instead of 2.5. From function void cartesianMeshExtractor::createMesh() in file cartesianMesh/cartesianMeshExtractor/cartesianMeshExtractor.C at line 108. FOAM exiting It works when I give maxcellSize of 4 or higher. I tried using local refinements to get fine mesh , but if i specify cellSize less than 4 in local refinements it gives the same error. Can someone tell me where i am going wrong? Last edited by RAJ KIRAN; November 10, 2015 at 20:26. |
November 12, 2015, 07:25 |
Rajukiran Antham
Rep Power: 13 |
I am adding my case files, In case if any one want to check this.
Here is the link for files https://drive.google.com/open?id=0B2...nh2YWI3WjVURDg |
November 12, 2015, 18:40 |
Geometry is not a closed volume
The geometry is not closed. The mesher can handle coarse cells because the cells fill the holes. When you decrease the cell below 4 they become smaller than the holes, and the mesh leaks through those holes. You have to close the holes to be able to use smaller cell size.
Principal Developer of cfMesh and CF-MESH+ www.cfmesh.com Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram |
November 12, 2015, 20:07 |
Rajukiran Antham
Rep Power: 13 |
Thank you for the reply. I found out the mistakes in my geometry. This geometry is a part of my whole geometry. I overlooked this. I should have checked this things earlier, my bad. Sorry for troubling. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
keeping resolution of mesh in Dynamic mesh + Q about posprocessing the problem | M.Sc_Student | FLUENT | 3 | April 10, 2011 12:10 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
