Meshing of very small parts
Hi everyone,
I have a question concerning my next project. It is about a heatet wire in a channel and I want to simulate the heat transfer from the wire (constant temperature) to the fluid, dependent on the fluid composition. Anyway, at first I want to mesh that. The model is "only" a pipe (approx 10 cm diameter) and a wire in this pipe. The problem is, that the wire has a diameter of 5*10^-6 m. Has anyone of you already meshed such a small thing like this? Edit: Might be important to know, that I used blockMesh and snappyHexmesh until now. Thanks Best Gerrit |
2 Attachment(s)
Hi everyone,
I proceed with my meshing. By splitting my blockMesh into 4 blocks and refine it towards the centre (where the wire is placed) I gained a mesh that represents the geometry very well. Now I have still one issue: The command checkMesh -meshQuality gives me 703476 cells for the criterion "faces with face pyramid volume < 1e-13". As my model itself is tiny, the big question is: Does this matter? Isn't this criterion normally used to prevent negative cells? For the case someone wants to know this is my blockMesh: Code:
/*--------------------------------*- C++ -*----------------------------------*\ |
