February 14, 2016, 02:13 |
gambit to foam
Fatemeh
Rep Power: 10 |
Hi every one.
Would any one please please help me? I have prepared a 3D Mesh in gambit and exported it to openfoam. when running the command " fluent3DMeshToFoam" I see the following error"--> FOAM FATAL IO ERROR: wrong token type - expected word, found on line 0 the label 31 file: IStringStream.sourceFile at line 0. From function operator>>(Istream&, word&) in file primitives/strings/word/wordIO.C at line 74. FOAM exiting would any one please please tell me what to do? Thanks a lot |
March 12, 2016, 10:55 |
Artur
Rep Power: 19 |
Seems that for whatever reason OpenFOAM is expecting to find a word in one of the files but instead finds the number 31. My advice would be to export the mesh to ascii format and try to find the file which causes trouble by comparing to mesh files generated by blockMesh. I imagine it's probably a missing header somewhere which could be simply pasted in in most cases.
All the best, A |
April 7, 2016, 01:17 |
Akr
Rep Power: 11 |
This happend with me also.
It can be resolved by saving the mesh in ASCII format during the save mesh step!!!! cheers |
April 7, 2016, 01:54 |
Fatemeh
Rep Power: 10 |
Thanks and best regards
Display Modes | |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[Commercial meshers] gambit mesh to Foam problem | AmirBaqa1987 | OpenFOAM Meshing & Mesh Conversion | 1 | May 19, 2013 05:26 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 22:50 |
