[Commercial meshers] Separating regions Problem after importing from Fluent Mesher |
March 1, 2016, 07:42 |
Peter Hess
Rep Power: 16 |
Hello everybody,
I imported a multi-Regions Mesh from Fluent (Ansys) Mesher via command: fluent3DMeshToFoam It works well until here... To separate the regions from each other I used the command: splitMeshRegions -cellZones -overwrite This one made also the job partly done. The Problem is, after using this command, all the regions, that are physically separated, has been also separated and named separately... Actually, some of them belongs to the same region and have also the same name by importing and are connected to the same neighbours... - Should the command not collect them (the regions with the same name during importing) to one region? How could I fix that? - How could I recollect those regions to just one again? Thanks for your support Peter |
March 1, 2016, 08:45 |
Problem Solved
Peter Hess
Rep Power: 16 |
Using the command:
splitMeshRegions -cellZonesOnly -overwrite solved the problem. This command seems to separates the regions by name and not by walking through and searching the connection between the regions... thanks Peter |
Stefan problem using fluent | Isaacibp1401 | Fluent Multiphase | 2 | June 7, 2021 05:49 |
problem while importing file from chemkin to ansys in fluent | srinathsol | CFD Freelancers | 0 | June 12, 2017 07:33 |
Importing CFX to FLUENT | ckbenjamin | ANSYS | 1 | June 26, 2011 18:10 |
Problem with ICEM and Fluent: Automatically created Regions within the domain | sandmike_83 | ANSYS Meshing & Geometry | 0 | September 24, 2010 05:42 |
A problem about Importing mesh from fluent | aderliner | OpenFOAM Running, Solving & CFD | 0 | December 18, 2006 23:00 |
