March 7, 2016, 06:52 |
Meshing?
Alpha Beta
Rep Power: 10 |
Is meshed area, the area within which the fluid will be flowing?
That is my understanding of mesh.. correct me if I'm wrong. If so how do i include obstacles like a baffle plate. I'm attempting to study sloshing in tanks (cylindrical)... any ideas? I want to use gmsh or salome to do that so it's easier.. so how do I design the baffle plate? Will it be a solid within a solid (using Boolean operation to delete mesh where baffle plate is supposed to be)? Cause I intend to get the stress values on the plates as well. |
March 7, 2016, 08:16 |
#2 | |
Alex
Rep Power: 12 |
those are the areas left out in the meshing, as you wrote with a boolean operation. only the fluid is meshed. For this, you would have to implement an FSI (1 way should work). That way, you can project the pressure field of the CFD simulation onto a mechanical model of the baffle and let FEM calculate the stresses. Is that what you are trying to achieve? Cheers Alex |
March 7, 2016, 11:10 |
Alpha Beta
Rep Power: 10 |
What I'm trying to achieve is a simulation of what sloshing looks like without a baffle plate and also with a baffle plate but in various orientations/designs so as to get optimum effect.
My understanding so far is that I have to do the Boolean thing and get the effect without the actual model so that fluid is sloshing mid-air without any container :O .. then somehow add container later via blender or something... Is this right? And after I get meshed entity.. how do I slosh it about? :P (I have to fill container to a certain percentage.. is there a variable for this? or do I have to keep meshing about?) Any kind of help is appreciated |
March 7, 2016, 11:14 |
Alpha Beta
Rep Power: 10 |
[QUOTE=Kina;588464
For this, you would have to implement an FSI (1 way should work). That way, you can project the pressure field of the CFD simulation onto a mechanical model of the baffle and let FEM calculate the stresses. Is that what you are trying to achieve? Cheers Alex[/QUOTE] Pretty much .. but I'll do that later if I have time .. I could just run a simple stress analysis on the plate for now. |
March 8, 2016, 02:06 |
#5 | |
Alex
Rep Power: 12 |
I strongly recommend reading the damBreak tutorial. This will give you a first idea of what you might want to realize in terms of setup. |
March 11, 2016, 09:48 |
Help!!
Alpha Beta
Rep Power: 10 |
Hi Kina
I successfully ran the SloshingTank3d tutorial in the interDymFoam folder That is basically what I'm going for.. I tried to make a cylinder mesh with a boolean cut inside using salome. I meshed it and then created a surface group for the whole thing as 'walls' , exported it as unv and used ideasUnvToFoam and setfields and finally interDymfoam. The whole thing worked. But I cant see the moving water inside.. Its just the empty cylinder with a boolean cut inside swaying. Can't I use 'boxtocell' inside a cylinder? How do I half fill the cylinder? I'm assuming it's something other than 'boxTocell' although I don't see how this is a problem.. It should just fall down and splash all over.. right? And is the mesh right? I meshed it in Salome and then created "surface" group and grouped it as 'walls' In paraview it seemed wrong as only the surfaces were meshed.. there was no mesh inside the volume. I tried meshing and grouping as "volume" but the setfields command returns an error.. I'm guessing this method is totally wrong I don't know if its the mesh that's wrong or the setFieldsdict Please do Help. Thanks |
March 17, 2016, 13:48 |
#7 | |
Alpha Beta
Rep Power: 10 |
Hot a better way.. toposetdict contains some useful info on setting up the water phase (alpha.water file).
I'm using Quote:
In case anyone needed to know :P |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
[ANSYS Meshing] Meshing strategy for External Flows | Hybrid | ANSYS Meshing & Geometry | 0 | January 24, 2012 14:27 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
