Write out nonorthogonality and squness as fields?
Is it possible? Not just non-ortho faces but for all faces, so I can look at it in paraview.
Thank you, |
Well, I am not sure about writing it as fields, but you can run checkMesh on your case and then use foamToVTK to convert the faceSets/cellSets to VTKs that can be viewed in Paraview. Cheers, Antimony |
Thank you for your reply.
Thaths true, but that only works for highly-nonorthogonal faces. I would like to know this info for the entire mesh if possible, or at least for a range of nonorthogonality if that makes sense.. |
I actually stand corrected. Apparently you can do something of the sort that you mentioned using swak4Foam: http://www.cfd-online.com/Forums/ope...tml#post387378 Hope this helps. Cheers, Antimony |
