[snappyHexMesh] Problem with parallel run of snappyHexMesh
Old   April 11, 2016, 06:15
Default Problem with parallel run of snappyHexMesh
Lorenzo
Lorenzo92 is on a distinguished road
Hi everyone,
my problem is the following: I have to run SHM on a given geometry and I wanted to execute it in a parallel run with mpirun.
After the meshing is successfully done , I use reconstructPar -latestTime but when I perform this stage I get to a rather long list of warnings concerning lacking directories and libraries , which eventually end up with a Fatal Error.
It is quite strange since when the very same meshing is performed without parallelization, then no error occurs.
I would be grateful if anyone can give me a hint on what is going on, and maybe help me sort it out.
Thanks
Here the copy of the error statement after meshing on two processors has been terminated:
Finished meshing without any errors
Finished meshing in = 321.52 s.
End
Finalising parallel run
| \\ / O peration | Version: 2.4.0 |
| \\/ M anipulation | |
Build : 2.4.0-f0842aea0e77
Exec : reconstructPar -latestTime
Date : Apr 10 2016
Time : 14:25:37
Host : "user-X555LAB"
PID : 2716
Case : /home/user/Documenti/Lorenzo/Materie_quinto_anno/Tesi_Les_Naso/Manara_Copia/DeltaPTot
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : libswak4FoamParsers.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable:open(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libswak4FoamParsers.so"
--> FOAM Warning :
dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libsimpleSwakFunctionObjects.so"
--> FOAM Warning :
dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libswakFunctionObjects.so"
--> FOAM Warning :
dlopen error : libgroovyBC.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libgroovyBC.so"
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Reconstructing fields for mesh region0
Time = 0.0003
--> FOAM Warning :
From function polyMesh::readUpdateState polyMesh::readUpdate()
in file meshes/polyMesh/polyMeshIO.C at line 207
Number of patches has changed. This may have unexpected consequences. Proceed with care.
--> FOAM Warning :
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/user/Documenti/Lorenzo/Materie_quinto_anno/Tesi_Les_Naso/Manara_Copia/DeltaPTot/processor0/0.0003/polyMesh/pointProcAddressing at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Lorenzo92 is offline   Reply With Quote
Old   April 12, 2016, 02:45
Antimony is on a distinguished road
You might want to try first with reconstructParMesh and then use reconstructPar.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   April 12, 2016, 08:53
Lorenzo
It works now, thank you very much Antimony!
For the sake of clarity I just launched reconstructParMesh and then reconstructPar -latestTime.
But now I don't know what the two commands separately do, I thought to use reconstructPar-latestTime in order to reconstruct the meshes created by the two processors ( at the end of the latest time step, in my case correspondent to the layer addition). Please correct me if I'm wrong.
Old   April 13, 2016, 02:07
You are welcome!
As far as I understand it and have used it, reconstructParMesh puts the meshes together, but not the fields, which is taken care of by reconstructPar.
(http://cfd.direct/openfoam/user-guid...ard-utilities/)
Cheers,
Antimony
Old   April 14, 2016, 15:50
Lorenzo
So after having run my analysis in parallel mode I should reconstruct also the fields of pressure and velocity of course using reconstructPar.
Thanks a lot again!!
Old   April 15, 2016, 04:12
You are welcome!
Actually, if you want you are going to analyze your results in Paraview, you don't need to reconstruct. You can simply choose the "Decomposed Case" in the Case Type and you are good to go.
Cheers,
Antimony
Some questions about a multi region case run in parallel zfaraday OpenFOAM Running, Solving & CFD 5 February 23, 2017 10:25
[snappyHexMesh] SnappyHexMesh in Parallel problem swifty OpenFOAM Meshing & Mesh Conversion 10 November 6, 2015 04:40
Problem in parallel run with OpenFOAM Gitesh P OpenFOAM Running, Solving & CFD 2 June 1, 2014 06:05
[snappyHexMesh] snappyHexMesh parallel run error dhruv OpenFOAM Meshing & Mesh Conversion 2 February 16, 2012 04:34
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 17:11
