blockMesh merging
I am trying to merge 2 faces in openFoam 3.0.1 but i get the following error, my example is really easy.
/*--------------------------------*- C++ -*----------------------------------*\ Code:
Have you tried correcting for the inside-out definition of the first block? The X3 direction of the block is oriented in the opposite direction of what you would get when you take the cross product of X1 & X2. Cheers, Antimony |
Hi, Alejandro
This is because the faces of patches must be in a specific order. (From U-146) Quote:
/*--------------------------------*- C++ -*----------------------------------*\ Cheers, Weiwen |
thank u very much!!
merging problem
hi everybody ,
i had the same problem using mergePatchPairs .. but i corrected it thanks to your advice ! Thank you :) |
