[blockMesh] MergePatchPairs
Old   May 13, 2016, 08:32
Default MergePatchPairs
Alejandro
ancolli is on a distinguished road
I would like to merge the following example.
But I get an error when trying to merge the small box with the huge one (that consist of two blocks).
Anyone knows how to solve that problem
|  \\    /   O peration     | Version:  3.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
(10 10 0)//0
(0 10 0)
(-10 10 0) //2
(-10 -10 0) //3
(0 -10 0)
(10 -10 0)
(10 10 5)
(0 10 5)
(-10 10 5)
(-10 -10 5)
(0 -10 5)
(10 -10 5) //11
(5 5 -5)
(-5 5 -5)
(-5 -5 -5)
(5 -5 -5)
(5 5 0)
(-5 5 0)
(-5 -5 0)
(5 -5 0)
blocks
    hex (0 1 4 5 6 7 10 11) (10 30 20) simpleGrading (1 1 1)
    hex (1 2 3 4 7 8 9 10) (50 30 20) simpleGrading (1 1 1)
    hex (12 13 14 15 16 17 18 19) (50 30 20) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
(12 13 14 15)
    outlet
        type patch;
        faces
(11 10 7 6)
(10 9 8 7)
    isolation
        type wall;
        faces
(15 19 16 12)
(15 14 18 19)
(14 13 17 18)
(12 16 17 13)
(5 11 6 0)
(0 6 7 1)
(1 7 8 2)
(3 2 8 9)
(3 9 10 4)
(4 10 11 5)
 /* master1
        type patch;
        faces
(19 18 17 16)
    slave1
        type wall;
        faces
(4 5 0 1)
   slave2
        type wall;
        faces
(4 1 2 3)
mergePatchPairs
    //(master1 slave1)
    //(master1 slave2)
ancolli is offline   Reply With Quote
[blockMesh] mergePatchPairs problem when migrating from OFext1.6 to OFext3.1 ma-tri-x OpenFOAM Meshing & Mesh Conversion 2 January 12, 2021 04:23
[blockMesh] mergePatchPairs reducing a face to less than 3 points aow OpenFOAM Meshing & Mesh Conversion 2 June 1, 2018 17:37
[mesh manipulation] mergePatchPairs with multiple areas bjoern1 OpenFOAM Meshing & Mesh Conversion 1 October 1, 2015 07:07
[blockMesh] 2:1 refined 2D blockMeshDict with mergePatchPairs? chrisb2244 OpenFOAM Meshing & Mesh Conversion 0 December 1, 2014 23:52
[blockMesh] mergePatchPairs Misbehaving dancfd OpenFOAM Meshing & Mesh Conversion 2 July 20, 2011 00:08
