[Other] Mesh Refinment
Old   June 22, 2016, 01:59
Default Mesh Refinment
Fatemeh
fatemehfarshi62 is on a distinguished road
Hi every one!
I have a turbulent flow for a channel. But for a first approximation I modeled it in laminar condition. the results had an approximate error about 30-35%. Can I perform the mesh study on the laminar case or It has to be in turbulent case? Thanks for help.
fatemehfarshi62 is offline   Reply With Quote
Old   June 22, 2016, 08:38
Zbynek is on a distinguished road
The mesh-independent study is not limited to turbulent flows, although it needs to be said that the mesh refinement (as well as transition from the lower-order schemes to the higher-order schemes) has a very significant effect especially on the turbulent quantities. That's at least my personal experience.
An important thing is what the focus of your simulation is. If it is, for example, the boundary layer resolution, then mesh refinement is desirable near the walls, no matter whether the flow is turbulent or laminar (although I should probably say that the laminar flow does not have a real boundary layer - in this case, I refer rather to a region with a large velocity gradient).
You are saying that the error is about 30%. Error of what? Besides you said that the flow is turbulent but you modeled the channel as laminar so I wonder how you could compare anything (experiments vs computations)?
Zbynek is offline   Reply With Quote
Old   June 22, 2016, 10:08
Fatemeh
Hi! problem solved thank you. The point is in smooth channels velocity profiles are more or less similar to turbulent case.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[Other] conformed FSI mesh for unstructured fluid region ashish.svm OpenFOAM Meshing & Mesh Conversion 10 August 2, 2019 08:40
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
