August 21, 2016, 18:53 |
Porous Media using TopoSet
Roberto
Rep Power: 9 |
Dear Foamers,
I have some problems using TopoSet. I need to simulate a flow passing throw a porous media, please see the picture 1 attached. The pleat is a stl file. The only thing I need is somehow to make that OpenFoam recognize my stl file as a CellZone. The problem is: I have been using sHM, but when I split my mesh, (using surfaceFeatureExtract) it creates FaceZones and CellZones, because I enable in sHM to create a refinementSurface. Creating a CellZone is fine because I can, and I should, set in fvOptions my porous Media, but the flow does not pass through the other side of the pleat and I can not find a way to deal with sHM, so I decided to migrate to use TopoSet. Using TopoSet I could manage creating a Cellzone for my stl file just when I create a blockMesh that involves all my pleat, not like in the picture. However, when I try to set TopoSet using the picture 1, OpenFoam gives me those CellZones, please see the other pictures. The red part are my CellZones and they are different because I was playing around with SurfaceToCell, which means that the following code represents the picture 2. here is the code I used for my topoSet: Code:
{ name filter; type cellSet; action new; source surfaceToCell; // select based on surface // source zoneToCell; sourceInfo { file "$FOAM_CASE/constant/triSurface/testPleat.stl"; outsidePoints ((1 1 1)); // definition of outside includeCut true; // cells cut by surface includeInside true; // cells not on outside of surf includeOutside false; // cells on outside of surf useSurfaceOrientation false; // use closed surface inside/outside // test (ignores includeCut, // outsidePoints) nearDistance -1;//-1 // cells with centre near surf // (set to -1 if not used) //- If > 0 : include cells with distance from cellCentre to surface // less than nearDist. curvature 0.9; // cells within nearDistance // and near surf curvature // (set to -100 if not used) } }/**/ { name pleat; type cellZoneSet; action new; source setToCellZone; sourceInfo { set filter; } }/**/ Thank you very much for your time! Roberto Last edited by RobertoCirolini; August 23, 2016 at 09:57. |
August 23, 2016, 08:59 |
Roberto
Rep Power: 9 |
Hi again,
maybe my explanation was not very understandable. Please let me know. But I still cannot manage to set my cellzone properly. I tried to use topoSet in a simple mode, a square. The square is a stl file and I made it in paraview. Therefore I used the following code to set my CellZone, and it works (for that square). Please, see the picture 4. Code:
{ name filter; type cellSet; action new; source surfaceToCell; // select based on surface sourceInfo { file "$FOAM_CASE/constant/triSurface/testPleat.stl"; outsidePoints ((1 1 1)); // definition of outside includeCut false; // cells cut by surface includeInside true; // cells not on outside of surf includeOutside false; // cells on outside of surf useSurfaceOrientation true; // use closed surface inside/outside // test (ignores includeCut, // outsidePoints) nearDistance -1;//-1 // cells with centre near surf // (set to -1 if not used) //- If > 0 : include cells with distance from cellCentre to surface // less than nearDist. curvature 0.9; // cells within nearDistance // and near surf curvature // (set to -100 if not used) } } Is there somebody who could give me some hint, please? Thank you in advance Last edited by RobertoCirolini; August 23, 2016 at 10:57. |
August 25, 2016, 16:19 |
Roberto
Rep Power: 9 |
Any suggestions?
August 30, 2016, 09:34 |
Roberto
Rep Power: 9 |
Hi, just to finish this thread,
I have found a solution for my problem. Using topoSet I've just selected the other cells of my configuration in the picture 5, using "actions" and "invert". Besides I have also created two boxes "boxToCell" to delete the regions that were not important for my simulation, front and behind of my pleat. That is all. Cheers, Roberto |
snappyhexmesh, surfacetocell, toposetdict |
Display Modes | |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 03:55 |
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 7 | May 14, 2020 17:34 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 05:09 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 11:34 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 16:16 |
