[Gmsh] 3D mesh using transfinite surface + extrude with layer? |
July 5, 2016, 02:26 |
OpenFoam
Rep Power: 9 |
Hey All,
I have been reading and practising how to create a 3D mesh in gmsh. I have come to a question I was not able to answer. Anyway, I created two line with following coordinates; Point(1) = {2.5, 0, 0, 0.0}; Point(2) = {5.25, 0, 0, 0.0}; Point(3) = {8, 0, 0, 0.0}; Then I extruded the same points 14 in the z direction using the following points; Point(4) = {2.5, 0, 14, 0.0}; Point(5) = {5.25, 0, 14, 0.0}; Point(6) = {8, 0, 14, 0.0}; Now, I have two rectangles with tow Plane surfaces as shown below; pic1.jpg I created a grid for the two rectangles as shown below using transfinite surface algorithm; Transfinite Line {5, 2, 4, 1} = 20 Using Progression 1; Transfinite Line {6, 7, 3} = 100 Using Progression 1 Transfinite Surface "*"; Recombine Surface "*"; pic2.jpg Now that we have a 2d mesh, I thought that it is easy to rotate four times to obtain the full 3d for the cylinder as shown below; pic3.jpg pic4.jpg pic5.jpg All I want to do is maintaining the same 2d mesh size that I created using transfinite to be set in all 3d domain. To do so, when I applied extrude the 2d surface, I used the command layer{30};, which it totally do not know what it does as follows; Extrude {{0, 0, 1}, {0, 0, 0}, Pi/2} { Surface{9, 11}; Layers{30}; } Extrude {{0, 0, 1}, {0, 0, 0}, Pi/2} { Surface{33, 55}; Layers{30}; } Extrude {{0, 0, 1}, {0, 0, 0}, Pi/2} { Surface{99, 77}; Layers{30}; } Extrude {{0, 0, 1}, {0, 0, 0}, Pi/2} { Surface{121, 143}; Layers{30}; } Applying extrude command and Layer{30} has created a mesh that look reasonable, but it did not match the mesh size of the two rectangles that I created earlier. Can somebody explain how the command layer works and how can I create it with the same size of the 2d before extrusion? Thank you in advance, |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 19:34 |
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges | olek.warc | OpenFOAM Meshing & Mesh Conversion | 1 | August 31, 2018 11:31 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
