mo_na |
July 22, 2016 06:59 |
snappyhexmesh with cyclicAMI
2 Attachment(s)
Hi everyone,
I am not sure if this is leading somewhere, but I decided to start working with cyclicAMI.
I left out the solid not moving body for now and started building a new mesh with blockMesh (sorry the numbering might be quite confusing) and defined two AMI patches on the cylindrical edge that is supposed to move later, orientating on the mixerVesselAMI2D tutorial.
The blockMesh result (ami1.png) looks fine to me.
The problems arise when i try to snap in the geometry with snappyHexMesh. At first I specified the locationInMesh somewhere outside the cylindrical part and the inner part just disappears (ami2.png). If I specifiy the locationInMesh inside the cylindrical part I get this error message:
--> FOAM FATAL ERROR:
Supplied field size is not equal to target patch size
source patch = 0
target patch = 0
supplied field = 400
From function AMIInterpolation::interpolateToSource(const UList<Type>&, const CombineOp&, List<Type>&, const UList<Type>&) const
in file /home/thesis/wilhelm/OpenFOAM/OpenFOAM-3.0.1/src/meshTools/lnInclude/AMIInterpolation.C at line 1256.
What am I missing? Do I need to have two meshes and then snap the smaller one into the bigger one later or stitch them together?
Also if anyone has ideas how to deal with the second body, I would really appreciate it!
Thanks for your time :)
defintions.m4:
// General m4 macros
changecom(//)changequote([,])
define(calc, [esyscmd(perl -e 'use Math::Trig; use POSIX; printf ($1)')])
// User-parameters
convertToMeters 1;
//coordinates
define(R, 0.65)
define(a, 0.4596194078) //x and z coordinate of corner point on circle
define(b, 0.4)
define(x1,-9.83) //beginning of tank
define(x2, calc(-a))
define(x3, calc(a))
define(x4, 6.47) //end of tank
define(y1, 0)
define(y2, 0.01)
define(z1, -0.95) bottom of tank
define(z2, calc(-a))
define(z3, calc(a))
define(z4, 0.95)
//grading
define(u1, 500) // u-cells in upstream
define(u2, 100) // u-cells in box
define(u3, 300) // u-cells in downstream
define(v1, 1) // v-cells in box
define(w1, 30) // w-cells low
define(w2, 100) // w-cells box
define(w3, 30) // w-cells upper
define(c, 30) //circles
define(ug1, 1) // u-cells grading in upstream
define(ug2, 1) // u-cells grading in box
define(ug3, 1) // u-cells grading in downstream
define(vg1, 1) // v-cells grading in box
define(wg1, 1) // w-cells grading low
define(wg2, 1) // w-cells grading box
define(wg3, 1) // w-cells grading upper
blockMeshDict.m4:
| \\ / O peration | Version: 1.3 |
| \\ / A nd | Web: http://www.openfoam.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
object blockMeshDict;
include(definitions.m4)
// User-parameters
convertToMeters 1;
vertices
( x1 y1 z1) //0
( x2 y1 z1) //1
( x3 y1 z1) //2
( x4 y1 z1) //3
( x1 y1 z2) //4
( x2 y1 z2) //5
( x3 y1 z2) //6
( x4 y1 z2) //7
( x1 y1 z3) //8
( x2 y1 z3) //9
( x3 y1 z3) //10
( x4 y1 z3) //11
( x1 y1 z4) //12
( x2 y1 z4) //13
( x3 y1 z4) //14
( x4 y1 z4) //15
( x1 y2 z1) //16
( x2 y2 z1) //17
( x3 y2 z1) //18
( x4 y2 z1) //19
( x1 y2 z2) //20
( x2 y2 z2) //21
( x3 y2 z2) //22
( x4 y2 z2) //23
( x1 y2 z3) //24
( x2 y2 z3) //25
( x3 y2 z3) //26
( x4 y2 z3) //27
( x1 y2 z4) //28
( x2 y2 z4) //29
( x3 y2 z4) //30
( x4 y2 z4) //31
( calc(b) 0 calc(-b)) //32
( calc(b) 0 calc(b)) //33
(calc(-b) 0 calc(b)) //34
(calc(-b) 0 calc(-b)) //35
( calc(b) y2 calc(-b)) //36
( calc(b) y2 calc(b)) //37
(calc(-b) y2 calc(b)) //38
(calc(-b) y2 calc(-b)) //39
( x2 y1 z2) //5-40
( x3 y1 z2) //6-41
( x2 y1 z3) //9-42
( x3 y1 z3) //10-43
( x2 y2 z2) //21-44
( x3 y2 z2) //22-45
( x2 y2 z3) //25-46
( x3 y2 z3) //26-47
blocks
//inner blocks
hex ( 1 5 21 17 0 4 20 16) (w1 v1 u1) simpleGrading (ug1 vg1 wg1) //0
hex ( 2 6 22 18 1 5 21 17) (w1 v1 u2) simpleGrading (ug2 vg1 wg1) //1
hex ( 3 7 23 19 2 6 22 18) (w1 v1 u3) simpleGrading (ug3 vg1 wg1) //2
hex ( 5 9 25 21 4 8 24 20) (w2 v1 u1) simpleGrading (ug1 vg1 wg2) //3
hex (32 33 37 36 35 34 38 39) (w2 v1 u2) simpleGrading (ug2 vg1 wg2) //4
hex ( 7 11 27 23 6 10 26 22) (w2 v1 u3) simpleGrading (ug3 vg1 wg2) //5
hex ( 9 13 29 25 8 12 28 24) (w3 v1 u1) simpleGrading (ug1 vg1 wg3) //6
hex (10 14 30 26 9 13 29 25) (w3 v1 u2) simpleGrading (ug2 vg1 wg3) //7
hex (11 15 31 27 10 14 30 26) (w3 v1 u3) simpleGrading (ug3 vg1 wg3) //8
hex (41 32 36 45 40 35 39 44) (c v1 u2) simpleGrading (1 1 1) //9 (0.8 1 1)
hex (41 43 47 45 32 33 37 36) (w2 v1 c) simpleGrading (1 1 1) //10 (1 1 0.8)
hex (33 43 47 37 34 42 46 38) (c v1 u2) simpleGrading (1 1 1) //11 (1.25 1 1)
hex (35 34 38 39 40 42 46 44) (w2 v1 c) simpleGrading (1 1 1) //12 (1 1 1.25)
edges
arc 5 6 (0 0 calc(-R))
arc 21 22 (0 y2 calc(-R))
arc 6 10 (calc(R) 0 0)
arc 22 26 (calc(R) y2 0)
arc 10 9 (0 0 calc(R))
arc 26 25 (0 y2 calc(R))
arc 9 5 (calc(-R) 0 0)
arc 25 21 (calc(-R) y2 0)
boundary
inlet
type patch;
faces
( 0 4 20 16)
( 4 8 24 20)
( 8 12 28 24)
outlet
type patch;
faces
( 3 7 23 19)
( 7 11 27 23)
(11 15 31 27)
atmosphere
type patch;
faces
(13 29 28 12)
(14 30 29 13)
(15 31 30 14)
middle
type symmetryPlane;
faces
( 1 5 4 0)
( 2 6 5 1)
( 3 7 6 2)
( 5 9 8 4)
( 7 11 10 6)
( 9 13 12 8)
(10 14 13 9)
(11 15 14 10)
(41 43 33 32)
(33 43 42 34)
(35 34 42 40)
(41 32 35 40)
(32 33 34 35)
maxY
type symmetryPlane;
faces
(17 21 20 16)
(18 22 21 17)
(19 23 22 18)
(21 25 24 20)
(23 27 26 22)
(25 29 28 24)
(26 30 29 25)
(27 31 30 26)
(45 47 37 36)
(37 47 46 38)
(39 38 46 44)
(45 36 39 44)
(36 37 38 39)
bottom
type wall;
faces
( 1 17 16 0)
( 2 18 17 1)
( 3 19 18 2)
AMI1
type cyclicAMI;
neighbourPatch AMI2;
transform noOrdering;
faces
(6 10 26 22)
(10 26 25 9)
(5 9 25 21)
(6 22 21 5)
AMI2
type cyclicAMI;
neighbourPatch AMI1;
faces
(41 43 47 45)
(43 47 46 42)
(40 42 46 44)
(41 45 44 40)
mergePatchPairs
snappyHexMeshDict:
| \\ / O peration | Version: 1.0 |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
convertToMeters 1;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
geometry
new_absorber-r.stl
type triSurfaceMesh;
name floatingObject;
patchInfo
type wall;
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// While refining maximum number of cells per processor. This is basically
// the number of cells that fit on a processor. If you choose this too small
// it will do just more refinement iterations to obtain a similar mesh.
maxLocalCells 40000000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 1500000;
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 100;
// Allow a certain level of imbalance during refining
// (since balancing is quite expensive)
// Expressed as fraction of perfect balance (= overall number of cells /
// nProcs). 0=balance always.
maxLoadUnbalance 2;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 1;
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
floatingObject
level (1 1);
// Resolve sharp angles
resolveFeatureAngle 50;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the locationInMesh is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
locationInMesh (-7 0.001 -0.5);
// Whether any faceZones (as specified in the refinementSurfaces)
// are only on the boundary of corresponding cellZones or also allow
// free-standing zone faces. Not used if there are no faceZones.
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 10;//10
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 4.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 10; //10;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 7;
//- Highly experimental and wip: number of feature edge snapping
// iterations. Leave out altogether to disable.
nFeatureSnapIter 20;
// Settings for the layer addition.
addLayersControls
relativeSizes false;
// Per final patch (so not geometry!) the layer information
layers
floatingObject
nSurfaceLayers 1;
// Expansion factor for layer mesh
expansionRatio 1.25;
//- Wanted thickness of final added cell layer. If multiple layers
// is the
// thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
finalLayerThickness 0.001; //0.0053;
//- Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.000003;
//- If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
nGrow 1;
// Advanced settings
//- When not to extrude surface. 0 is flat surface, 90 is when two faces
// make straight angle.
featureAngle 60;// was 45
nRelaxIter 15; //15;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 5; //20;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 15; //20;
// Smooth layer thickness over surface patches
nSmoothThickness 15; //20;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 1;//0.9;
// Angle used to pick up medial axis points
minMedianAxisAngle 180;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations
nLayerIter 20; //20;
// Max number of iterations after which relaxed meshQuality controls
// get used. Up to nRelaxIter it uses the settings in meshQualityControls,
// after nRelaxIter it uses the values in meshQualityControls::relaxed.
nRelaxedIter 10; //20;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 65; //90;
//- Max skewness allowed. Set to <0 to disable.
maxBoundarySkewness 20;
maxInternalSkewness 4;
//- Max concaveness allowed. Is angle (in degrees) below which concavity
// is allowed. 0 is straight face, <0 would be convex face.
// Set to 180 to disable.
maxConcave 180; //90;
//- Minimum projected area v.s. actual area. Set to -1 to disable.
minFlatness 0.2; //0.5;
//- Minimum pyramid volume. Is absolute volume of cell pyramid.
// Set to very negative number (e.g. -1E30) to disable.
minVol 1e-20;
//- Minimum quality of the tet formed by the face-centre
// and variable base point minimum decomposition triangles and
// the cell centre. This has to be a positive number for tracking
// to work. Set to very negative number (e.g. -1E30) to
// disable.
// <0 = inside out tet,
// 0 = flat tet
// 1 = regular tet
minTetQuality -1000; // 1e-9;
//- Minimum face area. Set to <0 to disable.
minArea -1;
//- Minimum face twist. Set to <-1 to disable. dot product of face normal
//- and face centre triangles normal
minTwist 0.001; //0.025;
//- minimum normalised cell determinant
//- 1 = hex, <= 0 = folded or flattened illegal cell
minDeterminant 0.001;
//- minFaceWeight (0 -> 0.5)
minFaceWeight 0.02;
//- minVolRatio (0 -> 1)
minVolRatio 0.001;
//must be >0 for Fluent compatibility
minTriangleTwist -1;
//- if >0 : preserve single cells with all points on the surface if the
// resulting volume after snapping (by approximation) is larger than
// minVolCollapseRatio times old volume (i.e. not collapsed to flat cell).
// If <0 : delete always.
//minVolCollapseRatio 0.1; //0.5;
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- amount to scale back displacement at error points
errorReduction 0.75;
// Optional : some meshing phases allow usage of relaxed rules.
// See e.g. addLayersControls::nRelaxedIter.
relaxed
maxNonOrtho 180;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
