[snappyHexMesh] Unable to run with multiple processor |
July 27, 2016, 08:58 |
Almond Wong
Rep Power: 9 |
I am trying to use decomposePar and run snappy with multiple processors. But i got this message: Code:
[linux4:09693] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file ess_env_module.c at line 367 [linux4:09694] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file ess_env_module.c at line 367 [linux4:09695] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file ess_env_module.c at line 367 [linux4:09691] tcp_peer_recv_connect_ack: invalid header type: 838598656 [linux4:09691] tcp_peer_recv_connect_ack: invalid header type: 838598656 [linux4:09691] tcp_peer_recv_connect_ack: invalid header type: 838598656 ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code.. Per user-direction, the job has been aborted. ------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[12796,1],1] Exit code: 1 |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 16:22 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
