[snappyHexMesh] Rhino surface problem in SnappyHexMesh |
August 10, 2016, 11:22 |
Diana Hurtado B.
Hi everybody!
I'm trying to run a resistance simulation on OpenFOAM 3.0x using my own Hull generated on Rhinoceros. I followed the tutorial to export it to .STL format, but at the time to run snappyHexMesh I have this problem: ... Scaling iteration 6 Moving mesh using displacement scaling : min:0 max:1 Checking faces in error : non-orthogonality > 70 degrees : 856 faces with face pyramid volume < 1e-13 : 0 faces with face-decomposition tet quality < 1e-30 : 0 faces with concavity > 80 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.05 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.05 : 0 faces on cells with determinant < 0.001 : 0 Successfully moved mesh Patch points smoothed in = 14.31 s Morph iteration 0 ----------------- Calculating patchDisplacement as distance to nearest surface point ... --> FOAM Warning : From function autoSnapDriver::calcNearestSurface(..) in file autoHexMesh/autoHexMeshDriver/autoSnapDriver.C at line 1759 For point:125 coordinate1.44804 -0.0688446 0.0565973) did not find any surface within:0.0104167 metre. --> FOAM Warning : From function autoSnapDriver::calcNearestSurface(..) in file autoHexMesh/autoHexMeshDriver/autoSnapDriver.C at line 1759 For point:132 coordinate1 -0.0789813 0.0270923) did not find any surface within:0.0104167 metre. ... I have tried a lot of ideas and don't know how to solve it. Any idea? This is the link of Hull Geometry: https://www.dropbox.com/s/gh6kr41fpn...nL.stl.gz?dl=0 Diana |
[snappyHexMesh] snappyHexMesh generates not planar surface | krzychu111 | OpenFOAM Meshing & Mesh Conversion | 2 | April 23, 2020 16:38 |
[snappyHexMesh] SnappyHexMesh - surface is not removed | vmb | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2019 08:24 |
Problem with surface monitor position | jf90cl | FLUENT | 0 | April 28, 2016 11:41 |
[snappyHexMesh] Problem: after snappyHexMesh, the cells size are not the same | kanes | OpenFOAM Meshing & Mesh Conversion | 0 | January 25, 2016 08:06 |
[snappyHexMesh] bumpy on the surface of 3D wing in addlayer step with snappyHexMesh | Kim sung hwan | OpenFOAM Meshing & Mesh Conversion | 2 | April 21, 2015 03:51 |
