[snappyHexMesh] patch problem
Old   October 2, 2016, 09:07
Default patch problem
mike6427 is on a distinguished road
I need a little help, please. I'm trying to build a mesh with snappyHexMesh, it consist basically in a series of pipes, some of which are concentrics. Following your advice I first draw a cad model and add two bidimensional disks for the inlet and outlet patches inside the 3d model. Then I export three stl files, inlet outlet and main body, and after converting them from binary to ascii I merge them in a single file. I can correctly import the stl with patches inside in discretizer and build the mesh, but I see in parafoam that only outlet and main body are listed along with internal mesh, which was not inside my stl file. I can't understand why inlet is missing and outlet is available.
Thanks for any help.
mike6427 is offline   Reply With Quote
discretizer, snappy hex mesh, stl
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 36 January 7, 2015 00:31
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
