December 3, 2016, 10:46 |
mesh interface for multi region
Rep Power: 10 |
Hi
I want to mesh two region contain a cylinder inside a cube, so there is two region : first , cylinder . second, region between cylinder and cube. when i mesh both region by gambit i define one interface between them. i use chtMultiRegionFoam as solver. problem;; conduction heat transfer between these regions. But temoerature distribution shows that there is no connection between these region because one region doesnt sense the heat and temperature rise. question:: 1. how to mesh or define interface in this problem to connect these regions. any idea is welcome. best regards. |
December 4, 2016, 21:24 |
Vu
Rep Power: 9 |
Hi Jam,
what boundary condition have you defined for the interface between 2 regions? |
December 5, 2016, 03:52 |
Rep Power: 10 |
December 5, 2016, 07:23 |
Vu
Rep Power: 9 |
I've not used gambit so i'm not sure about how it handle the boundary condition, but if i'm not wrong you can try the cyclic boundary condition in this case because it allows two faces to communicate and exchange the data.
Regards |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 19:34 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
