December 16, 2016, 12:02 |
BlockMeshDict
Shuai Yuan
Rep Power: 9 |
Dear All,
If I use other software to generate mesh, does it mean that I don't need the blockMeshDict file? My understanding is I can use the mesh file to replace Polymesh. Is it correct? |
December 20, 2016, 16:21 |
Rep Power: 16 |
that's correct, the file blockMeshDict is an input file of the OpenFOAM tool blockMesh only. You're free to use any other mesh generation software, as long as it produces valid mesh files within the folder constant/polyMesh. Usually a conversion step is necessary when importing meshes from external software. A conversion is not necessary when using meshers such as snappyHexMesh or cfMesh which produce native OpenFOAM meshes. Cutter |
[blockMesh] Creating an axisymmetric piston cylinder in blockMeshDict | foadsf | OpenFOAM Meshing & Mesh Conversion | 9 | August 23, 2018 07:54 |
[blockMesh] 2:1 refined 2D blockMeshDict with mergePatchPairs? | chrisb2244 | OpenFOAM Meshing & Mesh Conversion | 0 | December 1, 2014 23:52 |
[Other] blockMeshDict not Matching Boundary | HassanDarian | OpenFOAM Meshing & Mesh Conversion | 0 | March 19, 2014 13:30 |
[blockMesh] OpenFOAM blockMeshDict | sihaqqi | OpenFOAM Meshing & Mesh Conversion | 2 | February 1, 2013 03:49 |
PLease somebody help:problem while changing blockMeshDict file | vivek070176 | OpenFOAM Installation | 1 | June 11, 2010 17:51 |
