autoPatch for SnappyHexMesh
Hello friends
How do we find autoPatch angle for snappyHexMesh upto 0-90 angle it produces 319 patches and above 90 it produces only 1 patches it's very difficult add layer in further steps |
snappyHexMesh for tee-junction
https://sites.google.com/site/snappy.../cylinder-case
Hello , I am doing mesh for T-Junction using snappyHexMesh using above tutorial for layer addition. The autoPatch utility mentioned in this tutorial is not working properly for t-junction and number patches exceeds or lessen than required patches what should be the problem??? |
Quick question: Which OpenFOAM version are you using?
OpenFOAM 2.3.1
even same problem for elbow.. but I can easily add layer for reducer and for annuals geometry |
Quick answer: You can use regular expressions in "snappyHexMeshDict" for selecting the patch names. For example, this is shown here: https://github.com/OpenFOAM/OpenFOAM...xMeshDict#L219 - which you also have in your installation, whose path is indicated by the following command:
echo $FOAM_TUTORIALS/incompressible/simpleFoam/motorBike/system/snappyHexMeshDict Code:
layers Code:
layers Code:
linux introduction to regular expressions |
while using autoPatch utility, when I use angle 0-90 it generate around 319 patches
on the other hand when I use angle >90 it generate only 1 patches so it's becomming complecated for layer additon as well as giving boundary condition. for T-junction the number of patches should be generate is equal to five should I submite case and stl Thanks and Regards Harshawardhan |
Quick answer: At least the STL file would come in handy to test and diagnose. It's possible that the STL file is not properly sorted or something like that... or maybe it's the numerical precision of the vertices...
What does surfaceCheck give you? Code:
surfaceCheck filename.stl |
Reading surface from "wall_1.stl" ...
Statistics: Triangles : 86 Vertices : 84 Bounding Box : (-127 -12.7 -12.5999) (127 12.7 12.7) Region Size ------ ---- solid 86 Surface has no illegal triangles. Triangle quality (equilateral=1, collapsed=0): 0 .. 0.05 : 1 0.05 .. 0.1 : 0 0.1 .. 0.15 : 0 0.15 .. 0.2 : 0 0.2 .. 0.25 : 0 0.25 .. 0.3 : 0 0.3 .. 0.35 : 0 0.35 .. 0.4 : 0 0.4 .. 0.45 : 0 0.45 .. 0.5 : 0 0.5 .. 0.55 : 0 0.55 .. 0.6 : 0 0.6 .. 0.65 : 0 0.65 .. 0.7 : 0 0.7 .. 0.75 : 0 0.75 .. 0.8 : 0 0.8 .. 0.85 : 0 0.85 .. 0.9 : 0 0.9 .. 0.95 : 0 0.95 .. 1 : 0 min 2.05166e-05 for triangle 62 max 0.0428367 for triangle 27 Edges: min 1.35491 for edge 113 points (-12.7 3.1106e-15 12.7)(-12.6279 1.35107 12.6279) max 254.02 for edge 5 points (127 -7.46487 -10.2745)(-127 -9.78552 -8.09529) Checking for points less than 1e-6 of bounding box ((254 25.4 25.2999) metre) apart. Found 0 nearby points. Surface is not closed since not all edges connected to two faces: connected to one face : 84 connected to >2 faces : 0 Conflicting face labels:84 Dumping conflicting face labels to "problemFaces" Paste this into the input for surfaceSubset Number of unconnected parts : 1 Number of zones (connected area with consistent normal) : 1 End |
