Refinement error
3 Attachment(s)
Hello Guys,
I was trying to mesh an stl file in sHM. But I am getting an error for the locationinMesh even though i used it correctly. I do not know why i am getting this error. I have attached two pictures and my log file(txt file) with this thread. In the picture i used the ruler command to show the point i specified in the locationinmesh command. If you could see the log file there are also many foam warnings mentioned regarding the polymesh tetdecomposition. Why am i getting this warning? The error i am getting is Code:
--> FOAM FATAL ERROR: Thank you Vignesh |
Have you looked at the output of blockMesh?
You guessed it right. I figured out the error was with the blockmesh domain definition and corrected it. I was able to run the simulation(after doing sHM) in a serial run. But when i tried to run in parallel i got an error stating "2D Mesh motion error". I could not figure out the reason for the error. If you have time please look at the following post and help me identify the error. I have attached the log file to the following post. https://www.cfd-online.com/Forums/op...ion-error.html |
