Fschi |
January 19, 2017 07:46 |
'cracks' in Mesh on surface using STL
3 Attachment(s)
I've got some troubles generating a good mesh with snappyHexMesh using HelyxOS as GUI.
I have a several surface-geometries of a car as STL. And I need to have a qood mesh, especially on the surface because its used for wallFilm modelling.
Below I've got 3 different pictures. The first shows the 'crack' in the mesh. The second the original STL at that point.
And in the third picture you can see the result using that mesh for the wallFilm-simulation. So it's not just some grafics problem in paraview.
I've tried to use implicit snapping, surfaceFeatureExtract, refinementBoxes but nothing helps...
Does anybody got an idea what to change?
That's the SnappyHexMeshDict for the mesh in the pictures
| o | |
| o o | HELYX-OS |
| o O o | Version: v2.4.0 |
| o o | Web: http://www.engys.com |
| o | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location system;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers true;
geometry
car_side.stl
type triSurfaceMesh;
name car_side;
appendRegionName false;
car_mirror.stl
name car_mirror;
car_window.stl
name car_window;
car_A_pillar.stl
name car_A_pillar;
refinementBox
type searchableBox;
min ( -0.2 -1.2 0.4 );
max ( 1.4 -0.3 1.4 );
castellatedMeshControls
features
refinementSurfaces
car_side
level ( 6 6 );
car_mirror
level ( 6 6 );
car_window.stl
level ( 3 3 );
car_A_pillar
level ( 6 6 );
refinementRegions
refinementBox
mode inside;
levels (( 1E5 4 ));
locationInMesh ( 1.0 -0.6 1.15 );
maxLocalCells 500000;
maxGlobalCells 4000000;
minRefinementCells 0;
nCellsBetweenLevels 3;
resolveFeatureAngle 30.0;
allowFreeStandingZoneFaces true;
planarAngle 30.0;
maxLoadUnbalance 0.1;
snapControls
nSolveIter 30;
nSmoothPatch 15;
tolerance 5.0;
nRelaxIter 20;
nFeatureSnapIter 25;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
addLayersControls
layers
relativeSizes true;
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.25;
nGrow 0;
featureAngle 130.0;
slipFeatureAngle 30.0;
nRelaxIter 5;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedialAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
nRelaxedIter 20;
writeVTK false;
noErrors false;
layerRecovery 1;
growZoneLayers false;
projectGrownUp 0.0;
meshQualityControls
maxNonOrtho 65.0;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80.0;
minFlatness 0.5;
minVol 1.0E-13;
minTetQuality 1.0E-15;
minArea -1.0;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1.0;
nSmoothScale 4;
errorReduction 0.75;
relaxed
maxNonOrtho 75;
debug 0;
mergeTolerance 1.0E-6;
autoBlockMesh false;
and checkMesh:
Checking geometry...
Overall domain bounding box (-1.5 -1.3 0.499994189) (3.5 7.236849546e-35 1.5)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-1.751362408e-17 5.916174453e-16 8.765075835e-16) OK.
Max cell openness = 6.012466732e-16 OK.
Max aspect ratio = 22.62027622 OK.
Minimum face area = 1.424391158e-07. Maximum face area = 0.01792372431. Face area magnitudes OK.
Min volume = 3.321075353e-10. Max volume = 0.002282463027. Total volume = 5.595986151. Cell volumes OK.
Mesh non-orthogonality Max: 66.78962882 average: 7.806298952
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 3.76298589 OK.
Coupled point location match (average 0) OK.
Mesh OK.
