March 5, 2018, 10:07 |
foamyHexMesh not installed
Dear all,
How is it possible that I have foamyHexMexh and the other foamy meshing tool NOT installed with my OpenFOAM 5.0 in Ubuntu 17, but I DO have the tutorials? Any way of fixing this? Regards, C. |
March 15, 2018, 06:32 |
Paul Palladium
Rep Power: 10 |
I have the same problem. The tutorial straightDuctImplicit doesn't work.
F |
March 15, 2018, 07:26 |
April 17, 2018, 06:01 |
Aaditya Maharashtra
Rep Power: 8 |
I have same problem, when i enter foamyHexMesh it shows: command not found
May 15, 2018, 23:53 |
Ed Barry
Rep Power: 7 |
It's probably not compiled. I find that every time I compile the whole suite of packages, there are some that fail quite often, incl foamyHexMesh. Go into the source and try to compile/recompile foamyHexMesh. You might need to try a few times, checking the error messages and acting accordingly.
July 13, 2018, 09:24 |
Jack B
Rep Power: 7 |
I am a beginner (haven't even used foamyHexMesh) but all I know is that the source code for these applications are in the following directory:
$WM_PROJECT_DIR/applications/utilities/mesh/generation Hope this helps |
[snappyHexMesh] foamyHexMesh boundary layers | zordiack | OpenFOAM Meshing & Mesh Conversion | 14 | January 2, 2020 11:55 |
Issues with poor performance in faster CPU | gian93 | Hardware | 9 | October 29, 2018 13:34 |
[OpenFOAM.org] 4.0: Install without foamyHexMesh | Hillie | OpenFOAM Installation | 4 | October 11, 2016 00:41 |
unable to install openfoam 1.7 using apt-get | maazhmd | OpenFOAM Installation | 7 | July 24, 2011 11:18 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
