[Commercial meshers] multiregionmesh generation in ansys workbench |
March 9, 2017, 13:29 |
Manu Chakkingal
Rep Power: 10 |
Hello
I would like to use mesh generated in ANSYS workbench for the solver chtMultiRegionFoam, What do I need Generate two solid geometries disconnected in a fluid domain. What did I try Generated mesh in ansys workbench after combining the geometry into a part while exporting geometry into the meshing section. what do I see I get a geometry with only a single fluid solid interface , though I have two solids in contact with fluid. both solids are considered together and thus forms a single solid-fluid coupling interface. Thus I cant give different boundary conditions at solid walls , seprately for the solid bodies. what else did I try Without converting into part while making geometry, I get required number of contact regions. Now I dont have any guarrentee that the solid fluid interface mesh is coupled properly. When I convert it into a .cas or .msh file and convert into OF readable format, it shows error showing the grid points in the solid and the nearby fluid region which is in contact with the solid are not equal in number. Thus fails in the initial mesh conversion stage itself. (It works fine for a single soid in fluid domain) What help do I need 1. Any method to create coupled interfaces i.e ways to form multiple parts. solid 1 with fluid1 (part1) solid2 with fluid1 (part2) or 2. Any other coupling method between solid and fluid which I could use to ensure the fluid and soid region in contact have same grid points. Thanks in advance
Regards Manu |
Ansys Workbench 17.1 not showing up..? | AlexRonto | ANSYS | 3 | May 5, 2022 03:28 |
ANSYS Workbench is hanging or taking too much time opening CFX tab after crashing | Mfaizan | CFX | 1 | April 15, 2016 02:46 |
Strange issue while launching ANSYS workbench in CentOS 6.4 | Philip_C | ANSYS | 11 | August 29, 2013 06:44 |
Gambit vs. Ansys workbench mesh generating | sanlee39 | Main CFD Forum | 2 | April 8, 2013 06:09 |
[ANSYS Meshing] Ansys geometry generation via Ansys Workbench | AmandaMBF | ANSYS Meshing & Geometry | 0 | July 27, 2012 07:49 |
