meshQualityDict: minVol for snappyHexMesh
I'm calculating the minVol in system/meshQualityDict with the following formula: minVol = a^3 / 8^lvl / x where a = size of a blockMesh element lvl = maximum refinement level x = some arbitrary number It seems that for values of x lower than 15-20 there are too many too small cells to produce a good mesh. So my question is: What should i choose for x, and why? |
Another question is, why is the minimum volume so important? Can I make a mesh with a too high resolution? The intuitive thinking would be that more elements mean more precise discretisation hence more exact results. Or is my thinking wrong?
Thanks! |
Quick answers:
See this blog post for a few examples: OpenFOAM: Interesting cases of bad meshes and bad initial conditions Also, look up (Google?) the difference between mesh requirements between DNS, LES and RANS (or RAS). Quote:
I know you're not obliged to answer anything and I appreciate any kind of help, I just made an elaborated 'bump'. IMO it's a good quote :)
Thanks (for now), let me do some googling... |
