Peter_600 |
July 25, 2017 05:57 |
Dynamic remeshing (mequite) in parallel not working [foam-extend-4.0]
Dear all,
I am currently investigating a case with a large mesh displacement and would like to use the dynamic remeshing library "dynamicTopoFvMesh" within foam-extend-4.0 (Suse Leap 4.21). For me it is very important that this feature also runs in parallel. According to the source code and some literature (e.g. http://www.personal.psu.edu/dab143/O...idt_slides.pdf or more recently http://www.sciencedirect.com/science/article/pii/S0021999115003782 )
this feature is able to run in parallel.
I tried to execute the tutorial "circCylinder3d" of foam-extend-4.0 in parallel. Unfortunately not successfully. The case is decomposed into 4 parts and I have used metis as decomposition method.
Are there any special requirements for the decomposition of the mesh for the dynamicTopoFvMesh class?
Here is my log file:
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: http://www.foam-extend.org |
| \\/ M anipulation | For copyright notice see file Copyright |
Build : 4.0-4fad65ce7cac
Exec : moveDynamicMesh -parallel
Date : Jul 25 2017
Time : 11:25:33
Host : linuxaec
PID : 15173
CtrlDict : "/home/peter/foam/foam-extend-4.0/tutorials/mesh/moveDynamicMesh/circCylinder3d/system/controlDict"
Case : /home/peter/foam/foam-extend-4.0/tutorials/mesh/moveDynamicMesh/circCylinder3d
nProcs : 4
Slaves :
3
linux.15174
linux.15175
linux.15176
Pstream initialized with:
nProcsSimpleSum : 0
commsType : nonBlocking
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
--> FOAM Warning :
From function dlLibraryTable::open(const fileName& functionLibName)
in file db/dlLibraryTable/dlLibraryTable.C at line 124
could not load /home/peter/foam/foam-extend-4.0/ThirdParty/packages/scotch-6.0.4/platforms/linux64GccDPOpt/lib/libptscotch.so: undefined symbol: _SCOTCHorderSaveMap
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicTopoFvMesh
Selecting metric Knupp
Selecting motion solver: mesquiteMotionSolver
From function MeshObject<Mesh, Type>::MeshObject(const Mesh& mesh)
in file /home/peter/foam/foam-extend-4.0/src/foam/lnInclude/MeshObject.C at line 47
Creating meshObject for type mesquiteMotionSolver
Selecting quality metric: AspectRatioGamma
Selecting objective function: LPtoP
Selecting optimization algorithm: FeasibleNewton
Outer termination criterion (tcOuter) was not found. Using default values.
Time = 0.1
Clear VTK directory
in file lnInclude/MeshObject.C at line 47
Creating meshObject for type pointMesh
Solving for point motion: Initial residual: 1 Final residual: 0.00906627 No Iterations: 16
Solving for point motion: Initial residual: 1 Final residual: 0.00982701 No Iterations: 30
~~~ Mesh Quality Statistics ~~~
Min: 0.588549
Max: 0.999837
Mean: 0.890643
Cells: 8406
dynamicTopoFvMesh::identifyCoupledPatches : Found 25 global points.
Processor priority: 4(0 1 2 3)
Processor rankings: 4(0 1 2 3)
[0] identifyCoupledPatches : Talking to processors: 3(1 2 3)
[3] identifyCoupledPatches : Talking to processors: 3(0 1 2)
[1] identifyCoupledPatches : Talking to processors: 3(0 2 3)
[2] identifyCoupledPatches : Talking to processors: 3(0 1 3)
void polyMesh::initMesh() : initialising primitiveMesh
[2] Writing out sent subMesh for processor: 0
[3] Writing out sent subMesh for processor: 0
Constructing fvMesh from components
[2] faceStarts: 8(312 312 312 312 335 350 411 419)
[2] faceSizes: 8(0 0 0 23 15 61 8 77)
[2] edgeStarts: 8(111 111 111 111 146 169 267 284)
[2] edgeSizes: 8(0 0 0 35 23 98 17 103)
[2] patchTypes: 8(0 1 2 3 -5 -2 -3 -1)
[2] Sending to [0]:: nEntities: (94 387 496 202 111 312 42 42 1488 8)
[0] Writing out sent subMesh for processor: 1
[3] faceStarts: 8(385 385 385 385 410 425 497 511)
[3] faceSizes: 8(0 0 0 25 15 72 14 92)
[3] edgeStarts: 8(139 139 139 139 176 199 313 342)
[3] edgeSizes: 8(0 0 0 37 23 114 29 124)
[3] patchTypes: 8(0 1 2 3 -4 -2 -3 -1)
[3] Sending to [0]:: nEntities: (111 466 603 247 139 385 50 50 1809 8)
[0] faceStarts: 8(850 859 876 876 910 1073 1089 1098)
[0] faceSizes: 8(9 17 0 34 163 16 9 192)
[0] edgeStarts: 8(316 327 354 354 407 660 692 711)
[0] edgeSizes: 8(11 27 0 53 253 32 19 264)
[0] patchTypes: 8(0 1 2 3 -3 -5 -4 -1)
[0] Sending to [1]:: nEntities: (221 975 1290 535 316 850 102 102 3870 8)
[1] Writing out sent subMesh for processor: 0
[1] faceStarts: 8(838 847 861 861 894 1057 1071 1079)
[1] faceSizes: 8(9 14 0 33 163 14 8 199)
[1] edgeStarts: 8(310 322 343 343 393 646 674 691)
[1] edgeSizes: 8(12 21 0 50 253 28 17 279)
[1] patchTypes: 8(0 1 2 3 -2 -5 -4 -1)
[0] Receiving from [1]:: nEntities: (222 970 1278 529 310 838 102 102 3834 8)
[1] Sending to [0]:: nEntities: (222 970 1278 529 310 838 102 102 3834 8)
[1] Receiving from [0]:: nEntities: (221 975 1290 535 316 850 102 102 3870 8)
[0] Writing out sent subMesh for processor: 2
[1] Writing out sent subMesh for processor: 2
[2] Receiving from [0]:: nEntities: (97 407 526 215 120 334 42 42 1578 8)
[0] faceStarts: 8(334 334 334 334 354 364 378 439)
[0] faceSizes: 8(0 0 0 20 10 14 61 87)
[0] edgeStarts: 8(120 120 120 120 149 165 187 289)
[0] edgeSizes: 8(0 0 0 29 16 22 102 118)
[0] Sending to [2]:: nEntities: (97 407 526 215 120 334 42 42 1578 8)
[0] Receiving from [2]:: nEntities: (94 387 496 202 111 312 42 42 1488 8)
[1] faceStarts: 8(139 139 139 139 151 161 176 199)
[1] faceSizes: 8(0 0 0 12 10 15 23 42)
[1] edgeStarts: 8(45 45 45 45 63 79 104 146)
[1] edgeSizes: 8(0 0 0 18 16 25 42 52)
[1] Sending to [2]:: nEntities: (53 198 241 95 45 139 20 20 723 8)
[2] Writing out sent subMesh for processor: 1
[0] Writing out sent subMesh for processor: 3
[2] faceStarts: 8(129 129 129 129 140 152 161 184)
[2] faceSizes: 8(0 0 0 11 12 9 23 39)
[2] edgeStarts: 8(42 42 42 42 58 76 91 133)
[2] edgeSizes: 8(0 0 0 16 18 15 42 50)
[1] Receiving from [2]:: nEntities: (49 183 223 88 42 129 20 20 669 8)
[0] faceStarts: 8(366 366 366 366 389 407 479 493)
[0] faceSizes: 8(0 0 0 23 18 72 14 89)
[0] edgeStarts: 8(130 130 130 130 163 192 306 335)
[0] edgeSizes: 8(0 0 0 33 29 114 29 119)
[0] Sending to [3]:: nEntities: (110 454 582 237 130 366 50 50 1746 8)
[2] Sending to [1]:: nEntities: (49 183 223 88 42 129 20 20 669 8)
[2] Receiving from [1]:: nEntities: (53 198 241 95 45 139 20 20 723 8)
[3] Receiving from [0]:: nEntities: (110 454 582 237 130 366 50 50 1746 8)
[0] Receiving from [3]:: nEntities: (111 466 603 247 139 385 50 50 1809 8)
Building local coupled maps...Done.
[3] Writing out sent subMesh for processor: 1
[1] Writing out sent subMesh for processor: 3
[3] faceStarts: 8(311 311 311 311 333 345 360 419)
[3] faceSizes: 8(0 0 0 22 12 15 59 78)
[3] edgeStarts: 8(110 110 110 110 143 161 185 285)
[3] edgeSizes: 8(0 0 0 33 18 24 100 104)
[3] Sending to [1]:: nEntities: (95 389 497 202 110 311 42 42 1491 8)
[3] Receiving from [1]:: nEntities: (103 423 541 220 120 339 42 42 1623 8)
[1] faceStarts: 8(339 339 339 339 363 381 440 453)
[1] faceSizes: 8(0 0 0 24 18 59 13 88)
[1] edgeStarts: 8(120 120 120 120 156 185 279 305)
[1] edgeSizes: 8(0 0 0 36 29 94 26 118)
[1] Sending to [3]:: nEntities: (103 423 541 220 120 339 42 42 1623 8)
[1] Receiving from [3]:: nEntities: (95 389 497 202 110 311 42 42 1491 8)
[2] Writing out sent subMesh for processor: 3
[2] faceStarts: 8(814 814 814 836 873 1032 1046 1059)
[2] faceSizes: 8(0 0 22 37 159 14 13 195)
[2] edgeStarts: 8(297 297 297 331 388 633 661 687)
[2] edgeSizes: 8(0 0 34 57 245 28 26 270)
[2] Sending to [3]:: nEntities: (221 957 1254 517 297 814 100 100 3762 8)
[3] Writing out sent subMesh for processor: 2
[0] Writing out received subMesh for processor: 1
[3] faceStarts: 8(846 846 846 868 905 1064 1078 1093)
[3] faceSizes: 8(0 0 22 37 159 14 15 201)
[3] edgeStarts: 8(312 312 312 344 402 647 675 706)
[3] edgeSizes: 8(0 0 32 58 245 28 31 278)
[3] Sending to [2]:: nEntities: (226 984 1294 535 312 846 100 100 3882 8)
[2] Receiving from [3]:: nEntities: (226 984 1294 535 312 846 100 100 3882 8)
[3] Receiving from [2]:: nEntities: (221 957 1254 517 297 814 100 100 3762 8)
[3] Writing out received subMesh for processor: 0
[2] Writing out received subMesh for processor: 0
[1] Writing out received subMesh for processor: 0
[0] Writing out received subMesh for processor: 2
[3] Writing out received subMesh for processor: 1
[0] Writing out received subMesh for processor: 3
[2] Writing out received subMesh for processor: 1
[3] Writing out received subMesh for processor: 2
void dynamicTopoFvMesh::moveCoupledSubMeshes() : Moving points for coupled subMeshes.
[1] Writing out received subMesh for processor: 2
[2] Writing out received subMesh for processor: 3
[1] Writing out received subMesh for processor: 3
void polyMesh::clearAddressing() : clearing topology
mpirun noticed that process rank 2 with PID 15175 on node linux exited on signal 11 (Segmentation fault).
I am looking forward to your comments and appreciate your help.
Peter
