[snappyHexMesh] blockMesh for multi-region snappy |
June 7, 2018, 17:19 |
Nejc
Rep Power: 9 |
I set up a multi-region case, meshing with snappyHexMesh. It seems to do its job but I have problems with outermost faces.
I create a background mesh with blockMesh, leaving the blockMeshDict.boundary empty so that defaultFaces is assigned. Usually I make background mesh just slightly bigger so snappy snaps easily and assigns my 'real' patches. But in multi-region setup, snappy creates new regions where the cells should have been removed because they were outside my model. If I make background mesh of exactly the same dimensions than my model (if it's a block, that is), I'm stuck with defaultFaces again. I could remove domain*/ folders and use changeDictionary and whatnot but I don't think that's the right way to do it. In the tutorial, blockMesh defines named boundary faces - that's what I can't / don't want to do. Tutorials from holzmann-cfd.com use a mesh created in SALOME... How do I really set up a multi-region snappyHexMesh? Thanks! Last edited by Tobi; June 24, 2020 at 12:05. |
June 12, 2018, 04:45 |
anonymous
Rep Power: 14 |
Hi!
What version do you use? In +v1712 (maybe in 1706 and 1612 too) you can define the inside points for the regions you want to keep, and it removes the regions you don't need, and you will have correct boundary names, conform mesh between regions, etc.. |
June 12, 2018, 05:25 |
Nejc
Rep Power: 9 |
I'm currently using Turbomachinery CFD's package in which I believe version 5.x is used from OF Foundation. However I'm switching to ESI-CFD's latest version because there's a blended wall function I really need. I'll check snappyHexMesh too and report back.
Thanks! |
June 12, 2018, 05:57 |
anonymous
Rep Power: 14 |
In v1712 check the $FOAM_UTILITIES/mesh/generation/snappyHexMesh/snappyHexMeshDict file. You will see there how can you define multiple regions with the locationsInMesh entry (i think this part is commented).
Good luck! |
multiregion |
Display Modes | |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Floating Point Error with kOmegaSST Turbulence Model | shipman | OpenFOAM Running, Solving & CFD | 5 | January 4, 2016 08:57 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Taking too much for run | Grimoli | OpenFOAM Running, Solving & CFD | 5 | November 26, 2013 20:07 |
