[mesh manipulation] Successive refinements?
Old   August 10, 2017, 05:24
Default Successive refinements?
badoumba
badoumba is on a distinguished road
Is it possible to successively refine existing mesh generated by SHM?
meshing > solving > refining > solving > refining ...
Thanks for sharing
badoumba is offline   Reply With Quote
Old   September 1, 2017, 01:11
Frederik
a_slow_old_man is on a distinguished road
If you make a seperate case for each "refined" mesh you should be good.
See U-33 to U-35 in the OpenFOAM User Guide
You just replace the refineMesh with a snappyHexMesh job
a_slow_old_man is offline   Reply With Quote
Old   September 20, 2017, 05:28
Marc
Dreoasteh is on a distinguished road
A good approach is to increase the cell count in blockMesh, that way the path snappyHexMesh takes is maintained. This is specially useful if you are doing grid independence studies.
Just take care because if you want to double the number of cells in your final mesh, (i.e. if your initial blockMesh was (10 10 10) and you want to go from 1M cells to 2M cells) you have to multiply each direction by cube root of 2. Don't be like me and multiply each direction by 2!
If this is your approach you can just write a bash script to concatenate the progressive refinements.
Hope it helps
Dreoasteh is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ANSYS Meshing] Refinements in areas of interest herrolsen ANSYS Meshing & Geometry 0 June 27, 2014 06:49
ABOUT successive ratio type in Gambit Emad FLUENT 0 March 11, 2008 16:05
Successive Mesh in Gambit ashish FLUENT 0 April 28, 2006 00:42
