[snappyHexMesh] extrudeMesh but retain sourcePatch as faceZone
Like Tree1Likes
  • 1 Post By jfw_cfd
Old   May 30, 2016, 08:34
Question extrudeMesh but retain sourcePatch as faceZone
Johannes
jfw_cfd is on a distinguished road
Hello!
After many hours of research without success, I need to open this new thread.
The following situation: I have a mesh (generated with snappyHexMesh) of a compressor with inlet and outlet boundary patches. I want to extrude an inlet channel and outlet channel, respectively, from these patches with extrudeMesh (extrude from mesh), which works fine and is already done.
But! I want to retain the original inlet and outlet boundary patch as an internal faceZone (or faceSet), since I want to do some postprocessing at these cross sections afterwards. How to do that? Any simple ideas? At the moment the sourcePatches (from the original mesh) are lost after the extrudeMesh operation.
BTW: OpenFOAM 2.4
Thanks in advance for your comments!
Regards,
Johannes
jfw_cfd is offline   Reply With Quote
Old   June 22, 2016, 10:32
Lightbulb a possible solution
Johannes
Hello & Hallo!
Just in case anybody is facing a similar problem, I post a solution (found by a colleague of mine) for the described problem.
My colleague found a solution/work around by using topoSet right after extrudeMesh with the following topoSetDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    inlet-fS;
        type    faceSet;
        action  new;
        source  cellToFace;
        sourceInfo
            set addedCells;
            option  all;
        name    bothaddedfaces-fS;
        type    faceSet;
        action  new;
        source  cellToFace;
        sourceInfo
            set addedCells;
            option  both;
        name    inlet-fS;
        type    faceSet;
        action  delete;
        source  faceToFace;
        sourceInfo
            set bothaddedfaces-fS;
        name    inlet-fS;
        type    faceSet;
        action  delete;
        source  patchToFace;
        sourceInfo
            name inletDisk;
        name    inlet-fS;
        type    faceSet;
        action  delete;
        source  patchToFace;
        sourceInfo
            name inletpipe;
        name    inlet-fZ;
        type    faceZoneSet;
        action  new;
        source  setToFaceZone;
        sourceInfo
            faceSet     inlet-fS;
        type    faceSet;
        action  remove;
        name    inlet-fS;
        type    faceSet;
        action  remove;
        name    addedCells;
        type    cellSet;
        action  remove;
In a few words about what this topoSetDict essentially does:
1 extract all faces from extruded mesh (in this case a pipe)
2 extract only internal faces (with "both" option)
3 subtract internal faces from all faces (so only bounding faces remain)
4 subtract wall and the outside pipe end (in this case the inlet), so what remains is the inside pipe end, the internal face used for postprocessing purposes later on
Hope this might be helpful for those who didn't already know ;-)
Regards,
Johannes
Alczem likes this.
Old   August 23, 2017, 04:59
Elena Valle
ElenaVM is on a distinguished road
Hello Johannes
Thanks for your information. I'm trying to create a axisymmetric mesh with internal walls, the 3D mesh is well done with SnappyHexMesh and I could integrate the internal walls. But since I need a 2D mesh I use this ExtrudeMesh tool, everything is fine with the boundary patche but for the internal walls they disappear and I have no data of them neither in cellZone file nor faceZone file. I tried to use the hint you gave here but since my cellZone file has no points I think it is not working. Do you have a idea to fix this?
Thank you very much!
ElenaVM is offline   Reply With Quote
extrudemesh, facezone, retain, source patch, toposet
[swak4Foam] swakExpression on faceZone returns empty field for non-empty zone jgross OpenFOAM Post-Processing 1 July 7, 2022 11:28
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
Calculate Mass Flowrate at a faceZone with OpenFOAM4 donQi OpenFOAM Post-Processing 1 August 31, 2016 21:13
Problem with Application based on a faceZone in parallel psilkeit OpenFOAM Programming & Development 2 April 28, 2016 09:47
