[snappyHexMesh] defining non-cubic blocks to toposet |
August 4, 2017, 08:55 |
sara jamali
Rep Power: 8 |
Dear all,
I am beginner in openfoam and would be thankful to have your recommendations. i want to define some blocks in toposet which are not rectangular cubes, they are Trapezoid cubes, so i cant use boxtocell . how can i define my blocks in toposet? Thanks |
August 15, 2017, 05:35 |
Rep Power: 15 |
Perhaps the option "rotatedBoxToCell" meets your requirements? https://openfoamwiki.net/index.php/TopoSet Cheers, Antimony |
August 26, 2017, 05:00 |
#3 | |
sara jamali
Rep Power: 8 |
thanks a lot for your response, i tried "rotatedBoxToCell", for some special cases it works, but it doesn't meet what i want exactly, or maybe its better to ask how can i define a pyramid region to toposet? |
August 26, 2017, 22:58 |
Rep Power: 15 |
I don't think there is a way to define a pyramid region directly in topoSet. The only reference to pyramids that I could find was on choosing by cell shape type (hex or pyr or tet etc). If you know how and where exactly the pyramid should be, you could perhaps do one of two things: 1. Create a STL of the pyramid and use surfaceToCell to create cellSet based on the pyramid STL 2. Break your pyramid into many "boxes" and repeatedly use boxToCell or rotatedBoxToCell as the case maybe. This would again, provide only an approximation, but might still be doable. Hope this helps/ Cheers, Antimony |
August 29, 2017, 09:41 |
sara jamali
Rep Power: 8 |
Dear Antimony,
thanks for your comment, I try the first method you mentioned. Regards Sara |
non-cubic blocks, toposet |
[blockMesh] Face reduced to less than 3 points (simple cubic blocks) | mikeR | OpenFOAM Meshing & Mesh Conversion | 7 | July 20, 2023 19:27 |
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface | manuc | OpenFOAM Meshing & Mesh Conversion | 1 | July 25, 2017 03:13 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
