[snappyHexMesh] SnappyHexMesh castellation stage creates hole in surface where mesh flows into domain |
August 30, 2017, 04:19 |
Rep Power: 9 |
Hello all!
In my case when I try to mesh a geometry, the castellation stage can't find one of surface of the geometry correctly. On that surface some holes appear, and the mesh floats into the domain through the holes. However, when I check the stl file by surfaceCheck, it says it is not closed but when I open the generated .obj files the surface is closed where the problem occurs. I've attached a picture of the .stl surface and the meshed surface together. To check if those holes responsible for this problem i've tried to tighten the domain (=reducing the domain length), and-as i expected-these holes were responsible for this problem. For other similar geometries where the stl is also not closed, but during the meshing these holes don't appear, I get a decent mesh without inflows. If you could help me out with this problem i'd appreciate that! Yours sincerly, David |
meshing, snappy |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 15:15 |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 09:26 |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] how to mesh a domain splitted in two? | aCFDuser | OpenFOAM Meshing & Mesh Conversion | 6 | August 19, 2015 08:27 |
