[Other] VTK to Foam
Old   November 28, 2005, 00:29
Default VTK to Foam
Guoxiang
liugx212 is on a distinguished road
Dear all:
I want to use our VTK mesh files in openfoam. But my VTKfoam does not work. So I want to write a converter to realize from VTK to foam. Could you please give advice?
Thanks a lot.
liugx212 is offline   Reply With Quote
Old   July 1, 2009, 07:58
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
I would also like to be able to convert VTK mesh files to OpenFOAM format.
Have you had any success?
Philip
bigphil is offline   Reply With Quote
Old   October 20, 2010, 06:40
Default .vtk mesh to Foam?
Bertrand Delvaux
Bertrand is on a distinguished road
i am a new user into the wonderful world of OpenFOAM, and I would like to know if you succeeded to transform .vtk mesh into a Foam-readable format?
Best regards,
Bertrand
Bertrand is offline   Reply With Quote
Old   October 3, 2017, 17:54
Default Any update on this
Ashish Kumar
ashish.svm is on a distinguished road
Hi, I am also looking for a code to convert VTK to FOAM. Please post here if there exists a code
ashish.svm is offline   Reply With Quote
Old   October 3, 2017, 21:01
Antimony is on a distinguished road
There is the vtkUnstructuredGridToFoam utility....
Cheers,
Antimony
Antimony is online now   Reply With Quote
Old   October 7, 2017, 19:11
Ashish Kumar
Originally Posted by Antimony View Post
Cheers,
Antimony
I could not find that utility, can you please help me to locate it.
Old   October 8, 2017, 22:47
Typo in the name. Should instead read, vtkUnstructuredToFoam
https://github.com/OpenFOAM/OpenFOAM...cturedToFoam.C
And it is present at: applications/utilities/mesh/conversion
Old   October 10, 2017, 13:46
Ashish Kumar
Thanks. I found it.
Actually, I am using foam extend 3.2 and it does not have the vtkUnstructuredToFoam utility. But I was able to use it from OpenFOAM 4.0 version.
But no cells are generated when I am using this utility. This is generating points, faces etc files which has zero points faces etc.
about my VTK input file: I am confident that my VTK file is accurate because I generated VTK from an openfoam mesh using foamToVTK.
If you have any insight on why vtkUnstructuredToFoam utility is generating blank points, faces etc then please let me know.
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
