[blockMesh] fatal error while doing blockMesh |
September 20, 2020, 07:53 |
Deutschland
Rep Power: 5 |
Hey everyone,
I am new to OpenFoam. I am trying to do wigley hull simulation. I was creating the background domain mesh using blockMesh and I got the following error /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _b45f8f6f58-20200629 OPENFOAM=2006 Arch : "LSB;label=32;scalar=64" Exec : blockMesh Date : Sep 20 2020 Time : 13:50:34 Host : LAPTOP-A0NOGRUJ PID : 536 I/O : uncollated Case : /home/sam/OpenFOAM/OpenFOAM-v2006/tutorials/wigleyHull nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&, Foam::IOstreamOption::compressionType) in file db/IOstreams/IOstreams/IOstreamOption.C at line 115 Unknown compression specifier 'compressed', using compression off --> FOAM Warning : From blockMesh in file findBlockMeshDict.H at line 36 Using the old blockMeshDict location: "constant/polyMesh/blockMeshDict" instead of the default location: "system/blockMeshDict" --> FOAM FATAL ERROR: "/home/sam/OpenFOAM/OpenFOAM-v2006/tutorials/wigleyHull/constant/polyMesh/blockMeshDict" From int main(int, char**) in file findBlockMeshDict.H at line 61. FOAM exiting blockMeshing is applied to a simple cube I tried googling the error and I couldn't find the solution. I would really appreciate if anyone could help. Thank you in advance. |
September 21, 2020, 07:25 |
Mark Olesen
Rep Power: 40 |
need to probably need to post your blockMeshDict. sounds like something strange in it.
September 24, 2020, 12:16 |
Deutschland
Rep Power: 5 |
Hey.
I found the solution for the error. OpenFoam was not able to access the file due to tp lack of permission. when I changed the permission it worked. Thank you. cheers vava10 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
[blockMesh] blockMesh FOAM FATAL IO ERROR | seyf7 | OpenFOAM Meshing & Mesh Conversion | 2 | April 27, 2017 16:44 |
[blockMesh] blockMesh fatal error, the default patch already has faces in it | samid | OpenFOAM Meshing & Mesh Conversion | 2 | February 17, 2014 13:35 |
[blockMesh] Fatal Error at blockMesh Generation - wedge | hiasl | OpenFOAM Meshing & Mesh Conversion | 1 | October 17, 2012 09:47 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
