[blockMesh] Error running blockMesh with mergePatchPairs on OF2.4.0 |
November 25, 2017, 10:39 |
Deep
Rep Power: 8 |
I tried to look up but didn't find any thread which deals with this issue. Perhaps it's something very silly!?
I'm getting this error when trying to run blockMesh for a very simple geometry. Code:
--> FOAM FATAL ERROR: Parameter out of range, lambda = 1 From function lineEdge::position(const scalar) in file curvedEdges/lineEdge.C at line 68. If it helps my dictionary is defined as follows: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; x_min -10; x_max 10; y_min 0; y_max 20; z_min 0; z_max 100; xp_min -10; xp_max 10; yp_min -4; yp_max 0; zp_min 20; zp_max 40; vertices ( //External Flow ($x_min $y_min $z_min) //0 ($x_min $y_min $z_max) //1 ($x_min $y_max $z_max) //2 ($x_min $y_max $z_min) //3 ($x_max $y_max $z_min) //4 ($x_max $y_max $z_max) //5 ($x_max $y_min $z_max) //6 ($x_max $y_min $z_min) //7 //Porous Zone ($xp_min $yp_min $zp_min) //8 ($xp_min $yp_min $zp_max) //9 ($xp_min $yp_max $zp_max) //10 ($xp_min $yp_max $zp_min) //11 ($xp_max $yp_max $zp_min) //12 ($xp_max $yp_max $zp_max) //13 ($xp_max $yp_min $zp_max) //14 ($xp_max $yp_min $zp_min) //15 ); blocks ( //Block 1 hex (0 1 2 3 4 5 6 7) (1 200 1000) simpleGrading ( //X Expansion Ratio 1 //Y Expansion Ratio ( (0.2 0.25 0.125) (0.8 0.50 1) (0.2 0.25 8) ) //Z Expansion Ratio ( (0.18 0.2 0.125) (0.24 0.5 1) (0.58 0.3 8) ) ) //Block2 hex (8 9 10 11 12 13 14 15) (1 40 40) simpleGrading ( //X Expansion Ratio 1 //Y Expansion Ratio ( (0.3 0.50 8) (0.7 0.50 1) //(0.2 0.25 8) ) //Z Expansion Ratio ( (0.2 0.25 8) (0.6 0.50 1) (0.2 0.25 0.125) ) ) ); edges ( ); boundary ( block1Walls { type wall; faces ( (7 6 1 0) (2 5 4 3) //(0 7 12 11) //(13 6 1 10) ); } block2Walls { type wall; faces ( (9 14 13 10) (15 8 11 12) ); } inlet1 { type patch; faces ( (0 3 4 7) ); } inlet2 { type patch; faces ( (14 9 8 15) ); } outlet { type patch; faces ( (1 6 5 2) ); } frontAndBack { type patch; faces ( (4 5 6 7) (0 1 2 3) (8 9 10 11) (12 13 14 15) ); } interface1 { type wall; faces ( (7 6 1 0) ); } interface2 { //type patch; faces ( (10 11 12 13) ); } ); //patches //( // patch interface1 // ( // (7 6 1 0) // ) // // patch interface2 // ( // (10 11 12 13) // ) //); mergePatchPairs ( // (interface1 interface2) ); // ************************************************************************* // |
November 25, 2017, 14:50 |
Deep
Rep Power: 8 |
This issue is resolved.
Apparently, graded meshing is not possible when dealing with multiple blocks. Such a pity! |
[blockMesh] mergePatchPairs with blockMesh | Ivanet | OpenFOAM Meshing & Mesh Conversion | 17 | May 4, 2021 10:32 |
[blockMesh] blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions | pythag0ra5 | OpenFOAM Meshing & Mesh Conversion | 1 | September 19, 2020 14:38 |
[mesh manipulation] mergePatchPairs after running blockMesh | ashishmagar600 | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2019 04:15 |
[blockMesh] mergePatchPairs reducing a face to less than 3 points | aow | OpenFOAM Meshing & Mesh Conversion | 2 | June 1, 2018 17:37 |
[blockMesh] BlockMesh documentation User Guide clearance of mergePatchPairs proposals | benru | OpenFOAM Meshing & Mesh Conversion | 0 | June 9, 2008 02:22 |
