Trouble using foamFormatConvert
Hello everyone,
I've tried to use foamFormatConvert to convert the polymesh files from binary format to ascii format. But, when I run it, it convert all files (points, boundaries, ...) except the "faces" file. Does anyone have the same problem? Thanks, Agnes |
Not sure if you're still working with this, but it appears the problem is in writeMeshObject.H. There's an if statement that filters out the faces file for some reason. I'm not experienced enough to say why (perhaps someone can help with that), but the faces IOobject does not get past:
io.typeHeaderOk<Type>(false) && io.headerClassName() == CheckType::typeName Code:
(io.typeHeaderOk<Type>(false) && io.headerClassName() == CheckType::typeName)||(runTime.timeName()=="constant"&&name=="faces") |
