March 4, 2018, 02:24 |
Multiple blocks for moving mesh
Rep Power: 8 |
Hi, I am doing a simulation of moving solid body obstacle within a rectangular fluid domain. I had referred movingCone, movingConeTopoChanger and stirring water case. I found out that all of them are using multiple blocks to create a hollow solid obstacle, instead of deleting the mesh cells by using subset mesh. Is there any reason of using this method?
I had tried subset mesh method but result shows extreme value field data. So, i was wondering is it subset mesh method not working, thus no one using this method. Extreme value of field data Another problem is The result doesn't show U, P and turbulence contour as expected (supposed to have high U between domain wall and obstacle wall as in the pic below). elev.jpg Is it because i use a larger distance between solid obstacle (car) and domain (shaft) wall, so the high U tends not to be focus there? Anyway, the value and contour is really out of my expected. But at least i can see some contour on top, side and bottom of car wall I want to try multiple block method, but facing error to create block with an internal face. As mentioned in this post below. Can i get some idea on this? https://www.cfd-online.com/Forums/op...tml#post682691 I would be grateful for any comment and suggestion. Thanks |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface | manuc | OpenFOAM Meshing & Mesh Conversion | 1 | July 25, 2017 03:13 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
