Acces to points and faces
I have a question regarding the acces to the "points" and "faces" file. These files were created by blockMesh. If I open them there's only a list of hieroglyphs. Can somebody tell me how to obtain the data? The core problem is to find out the order of the faces of one patch. I would be infinitely grateful for your help!!! |
It sounds like you need to change binary format to ascii in system/controlDict and than run: Code:
foamFormatConvert But it may also be interesting to load the data in paraview and use the generate Ids filter. Best Regards, Tom |
