[snappyHexMesh] How to assign consistently master/slave cyclics with createPatch
Old   January 28, 2021, 06:26
Default How to assign consistently master/slave cyclics with createPatch
Edoardo Gamba
Gambenius is on a distinguished road
Hi everyone, I'm working on a simpleFoam case of a FSAE car, I have modeled 3 fans using the fixedJump BC (also tried fanPressure with the fan curves but i get a lot of convergence problems).
I start from a surface stl of the fan, mesh it as a baffle in snappyHexMesh and then with createPatch i transform it into 2 couple patches, then with changeDictionary i set them as cyclics and apply the fixedJump BC.
My problem is really simple, createPatch chooses randomly who's master and who's slave, so in the end I have a 50% chance my fan is set up right (the jump needs to go in the +x direction).
Does anyone have an idea on how to make createPatch call master the patch on the -x side and slave the one opposite to it?
This problem is wasting my time since I have to check if the fan is actually blowing air and if it's not I need to use a changeDictionary just to change its fixedJump to a negative one to reverse the flow.
Thanks in advance
Gambenius is offline   Reply With Quote
createpatch, fixedjump, openfoam, snappyhexmesh
[mesh manipulation] createpatch not working when using layer addition in snappyHexMesh Dikkeunit OpenFOAM Meshing & Mesh Conversion 0 February 3, 2020 09:46
There is a bug in createPatch? feno102 OpenFOAM Pre-Processing 6 November 1, 2017 02:24
OF ext-3.2 new createPatch cyclics issue Jack001 OpenFOAM Pre-Processing 0 May 26, 2016 14:43
